Re: Vibration/hum 60-65mph
Discussion in 'Volvo Forum' started by Nick956, Sep 8, 2014.
  1. Nick956
    Nick956 Bobtail Member
    33
    7
    Apr 30, 2013
    Harlingen, Texas
  3. Lucar
    Lucar Road Train Member
    1,396
    891
    Aug 22, 2012
    Texas
    Check big nut behind transmission
  4. TexasPhoenix
    TexasPhoenix Medium Load Member
    540
    329
    Jul 16, 2009
    Wisconsin
    Got a bit more weight moved forward onto the steer with a trailer. Bobtailing there is a lot of different noises and vibrations. I have a midroof 730 and I get a bit nervous at times bobtailing as there is a totally different feel to the truck. Things go back to normal when I get a trailer attached. Have you done a tri-axle alignment recently?
  5. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    check every joint in your drive shaft,had the same problem in my fld.
  6. Nick956
    33
    7
    Apr 30, 2013
    Harlingen, Texas
    My mechanic says its the Carrie bearing and it has minimal play up and down and side to side. And I got a three axle alignment last week at TCI tire centers.
  7. StrongArm
    StrongArm Light Load Member
    50
    11
    Apr 2, 2014
    New York, NY
    I have a similar noise in an 04 International 4300 straight with dt466 and 6 speed. Noise happens between 50-60mph and changes or goes away with change in load and throttle. I had drive shaft redone, new U joints, and yokes etc. New tires on rear. Still no change. Not sure what it could be.
    Find a place that can put the truck on a dyno and isolate the noise.
  8. StrongArm
    50
    11
    Apr 2, 2014
    New York, NY
    Carrier bearing? On the drive shafts? My truck has 2. I just replaced with the rest of the driveshaft, didn't change much. They are not that expensive. Dana spicer makes them in china now under SPL name. I tryed to get the american made one and could not find it. Even my Int. dealer is pushing the China bearing and trying to charge the same price as the american made.
  9. zoekatya
    zoekatya Medium Load Member
    397
    99
    Mar 15, 2013
    strongarm this site won't let me reply back to you and they deleted your post. [email protected] is my email if you are still looking for someone.
  10. Samtruck
    Samtruck Bobtail Member
    Did you check the axle angles? Volvo corrected all axle angles in 2009. My DSM says they were all wrongly set from the beginning in all air suspensions. And it has been going on like that for many many years without being addressed by Volvo. All fellow truckers should know the change. Check if this qualifies for class action law suit;-)
  11. Nick956
    33
    7
    Apr 30, 2013
    Harlingen, Texas
    Ended ip being the front middle differential. A gear was broken and missing a tooth. Thus causing the hum and vibration.
    mp4694330 Thanks this.
