Rear ac not cooling but front's good?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joseph1853, Aug 15, 2021.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    I've got a 2016 Freightliner Cascadia and the rear ac does not get cold. This is with the truck running. The truck has an epu (park smart) setup and it's low on refrigerant so it doesn't cool when the truck is off and it's running but I would think that doesn't matter when the truck is running as the truck's ac is being used at that point. But the thing is when I turn the truck off the epu fan on the back of the truck runs for a bit and then stops making me think maybe the rear ac is run by the epu even while the truck is running. Anybody got any ideas on this?
  3. truckdriver31
    6,998
    8,365
    Sep 18, 2013
    expansion valve most like. whats the ac pressure gauges say when you hook them up.
  4. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    I haven't hooked up gauges to it yet as I wasn't sure it was the trucks ac and not the epu but I will as soon as I get the chance. Wouldn't issues with the expansion valve also cause the front ac to not cool though?
    truckdriver31 Thanks this.
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,929
    Apr 10, 2012
    Indiana
    Not necessqrily, ac refrigerant will follow the path of least resistance, so if your rear is blocked or closed more than the front, front will work better
    BUT i THINK that the parksmart system has the sleeper cooling exclusively and the front ac is done only with a crompressor from the engine, 2 completely seperate systems. The way to verify this would be tracing ac lines in the front to see if they go to the back at all.
    And rereading, you yourself say the parksmart system is low on refrigerant, so theres your answer. 2 seperate systems, so front is unaffected by rear refrigerant low and vice versa
    armo, truckdriver31 and joseph1853 Thank this.
  6. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Ok, so I need to get more freon in the park smart system. Need to find someone who can do that. You have to put freon in the system through the high side so you have to have that special machine to do it if I understand it correctly.
  7. Magoo1968
    Magoo1968 Road Train Member
    2,130
    5,677
    Mar 18, 2021
    St Malo mb
    Park smart is what cools the bunk ,for heat it can use park smart or truck engine . When my park smart got low on Freon it kept kicking engine fan due to codes.
  8. truckdriver31
    6,998
    8,365
    Sep 18, 2013
    they dont make freon anymore. the US banned it last year.
  9. skallagrime
    3,855
    9,929
    Apr 10, 2012
    Indiana
    Semantic point, "freon" generically means refrigerant to anyone only cursorily familiar with cooling systems.
    Freon is r22, im not aware of any vehicle uses of r22 as its refrigerant, r134a is the standard as far back as 95ish
    truckdriver31 and Magoo1968 Thank this.
  10. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    I didn't realize I needed to be specific. I thought everyone understands when the word freon is used we're referring to r134.
    Numb and truckdriver31 Thank this.
  11. skallagrime
    3,855
    9,929
    Apr 10, 2012
    Indiana
    The people that know enough to help dont care about loose terminology, unless youre the guy that put a few cans of r-12 in your 2015 freightliners system and cant figure out why its not working right... THEN we care about exact terminology
