rear breaks smell
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Karletto, Jan 7, 2015.
  1. Karletto
    Karletto Bobtail Member
    19
    Oct 2, 2008
    Slovenia
    Hello
    I hope i am in the right section...
    Just last weeks on rear axle our mechanics changed break pads and break drums. Since than i can smell burning breaks which gets stronget in decend of course.
    That never ever happened on old - previous ones!
    I am thinking all these parts are new and have a protected layer so it needs a bit of wear...
    What could it be??
  3. FuzzFace2
    FuzzFace2 Medium Load Member
    417
    137
    Jul 27, 2014
    Angier, N.C.
    First I would get back in touch with the people that did the job to see what they have to say. Or at least the nearest shop to have them take a look see at them. Over heated brakes will lead to bigger problems like no brakes and/or fire.
    Not knowing the inner working of truck air brakes all that well my guess is they are adjusted up too tight or not enough air PSI to release the spring brakes so they are dragging heating up and you get the smell.
    Dave ----
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    All depends on if they put new brake drums on at same time as they put the brake shoes on, if drums were not replaced the new brake shoes are only touching the drum in a small area and are burning down to where they will touch the entire brake drum.
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Compleatlly normal. New shoes will stink to high heaven first few hard brake applications. New shoes and drums will not only stink but smoke like crazy also. Normal. Just the paint burning off the drums. Bear in mind the smoke thing will only happen on the first couple hard brake applications. The stink can linger for months with new shoes bedding in.
  6. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    New brake shoes always smell hot for a while...
