Rear bunk fan switch blinking
Discussion in 'Volvo Forum' started by atv_idiot, Oct 18, 2016.
  1. atv_idiot
    atv_idiot Bobtail Member
    42
    6
    Oct 18, 2016
    So I got this truck almost two years ago. Its a 2008 VNL780 D16 with iShift. Roughly 850,000 miles. Its used to haul my 5th wheel toy hauler so its not used every day. I noticed when I went out to it the other day that it was a little sluggish to start and the fan switch for the rear bunk was blinking. It never did that before. Can anyone help or explain why that would start all of a sudden?
    Thanks
  3. Trkr3529
    Trkr3529 Light Load Member
    104
    66
    Feb 14, 2016
    When that light blinks it means low voltage, check your batteries one or more could be bad
  4. atv_idiot
    42
    6
    Oct 18, 2016
    Thanks Trkr! I find it odd that Volvo would use that to show low voltage. Makes sense since the truck has been sitting for a month
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    that rear panel is the most sensitive voltage point on a volvo it will start beeping and blinking when it sees low voltage, 04-06 had connections in the back that would corrode and drivers would go crazy cuz it would never stop beeping no matter what until the problem was fixed. It's a real piece of work as far as modules go i've had it cause a bunch of problems. Once i had a driver swear his truck was possessed when he was sleeping the sleeper light would come on and then blower and it would shut off in a few minutes all was being caused by a loose ground contact in the back of the module.
