Rear end slipping
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 6mmrem, Jan 6, 2022.
  1. 6mmrem
    6mmrem Bobtail Member
    21
    26
    Sep 16, 2018
    Neepawa,Mb. Canada
    2018 Pete 567 Eaton 18speed manual.
    Only 2way locking diff, interaxle and front axle. multiple drivers.
    So 2 drivers complaint of hearing clunking sounds at rear of truck. It spins out easy when starting up empty or full. No traction control light comes one and it does not engage traction control.
    I took truck for a with empty and full load, 63,000kg gross. It does spin out easy starting up, but I pulled some pretty big hills, crawling up a 30kph.
    But something still doesn't feel right.
    Anything I could check with this info.
  3. Deezl Smoke
    Deezl Smoke Medium Load Member
    507
    330
    Feb 12, 2011
    Hillsboro Oregon
    I'd like to help, but I dont know enough about the electronics.
    Disk brakes? Have you, or can you have a good look at the condition of the disk brakes? Check for temp differences between them each after an hours drive. I can't help but wonder if you have a brake issue causing both the noises and spin outs. Don't know, just a thought. Is it the same tire pair that spins out first each time?
  4. 6mmrem
    21
    26
    Sep 16, 2018
    Neepawa,Mb. Canada
    This one is still drum brakes. It went into shop right away, so didn't have time to fully diagnosis.
  5. Goodysnap
    Goodysnap Road Train Member
    3,724
    9,054
    Jul 12, 2017
    Vin please?
    What rear suspension type?
    Loaded or empty make any difference in the noise? Less loaded?
  6. 6mmrem
    21
    26
    Sep 16, 2018
    Neepawa,Mb. Canada
    Last 6 jd452046. Low air leaf suspension.
    Heard it full load.
