Rear Ends
Discussion in 'Experienced Truckers' Advice' started by Dave_in_AZ, Nov 12, 2015.
  1. Dave_in_AZ
    424,424
    I've never had a rear end go out ( knocks on table ). Anyone that has had this misfortune, do you get any warning, aside from a hi temp reading?
    Ozdriver Thanks this.
  3. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    I've had a one go bad with a single axle drive. I had no warning. The ring gear separated, Same as an axle shaft that separates. Plenty noise after, with no forward movement. No warning noise that I remember.
    Dave_in_AZ Thanks this.
  4. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    I've had a power divider almost explode. Had massive chunks of gears come out when the oil was drained, only symptom was the front seal was leaking.
  5. OLDSKOOLERnWV
    19,136
    289,323
    Had a power divider let go, no warning. Clunk clunk clunk..Loaded flatbed on level ground but it was very spongy, I could see the ground moving under the tandems as I backed into place. O'l K100 with Rockford rears, nice having parts at home. Fixed it in the driveway and rolled on.
    Dave_in_AZ and Ozdriver Thank this.
  6. Ozdriver
    Ozdriver Heavy Load Member
    770
    1,394
    Oct 16, 2015
    Australia
    You don't necessarily get a high temp reading. Back in 1981 I had a power divider literally explode in a White Road Boss with 38,000 lb Rockwells which were known to be a bit suspect in those days. I was starting on a steep hill and Bang!!! Gears and oil everywhere.
  7. Ozdriver
    770
    1,394
    Oct 16, 2015
    Australia
    Luckily they seem less likely to go bang nowadays, either they're made better or people spec them heavier.
  8. MACK E-6
    50,025
    238,261
    We had that happen about 5 years ago when some idiot decided to pull a 53 footer with the axles slid all the way to the rear back from New Jersey with 41,000 lbs on it with a single drive axle tractor. The entire rear end came completely out from under the tractor on S/B 295 in Delaware.
    I'll bet that moron is STILL wondering how that happened. :rolleyes:
    Bob Dobalina, Dave_in_AZ and mp4694330 Thank this.
  9. AModelCat
    164,662
    Not really any warning. You might get some whinning depending on whats about to fail but usually it just goes.
  10. mrbamcclain
    mrbamcclain Light Load Member
    258
    116
    May 25, 2011
    Hammond, La
    A loud bang and a free revving motor...does not sound like Heaven either!
  11. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    Have lost three around here.
    First was the truck we used to shunt. '95 T600. It went snap, snap intermittently for a while before it quit working entirely.
    Second was a '05. The driver said he didn't do anything it just started making noise when he backed into the spot at the rest area loaded. Couldn't move. He made the last 30 miles with the power divider on.
    Third was me. '98. Changed the diff oil and found filings. We think it was a bearing cage. No symptoms at all. Dodged a bullet there. Good reason to change your diff oil people.
    ChevyCam Thanks this.
