REAR Fog Light
Discussion in 'Trucks [ Eighteen Wheelers ]' started by michael calvert, Sep 17, 2012.
  1. michael calvert
    michael calvert Bobtail Member
    cant get the rear fog light to work at all
    bulb fine, so checked feed to back splitter box - nothing
    checked fuse - fine, but replaced to check an make sure
    the switch in cab wont illuminate when fog is turned on ?? hhmmm
    swapped relay (x2) still nothing
    any ideas
    vehicle is FL618 220bhp on a 53 plate
    cheers guys
  3. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    Splitter box must be your problem. The front foglights need to get cut out by the splitter box for the rear fog lights to work. Check the reverser switch on the tranny too.
    If you bought the rig used make sure sure someone didn't replace the fog light with a sun light.
    And BTW you can crank up the power on that FL 618 by increasing the compression gap to -.005".
    Good luck!
