Rear trailer upper marker lights
Discussion in 'Ask An Owner Operator' started by Flatbedotr, Mar 15, 2024.
  1. Flatbedotr
    Flatbedotr Light Load Member
    103
    36
    Nov 26, 2018
    I have a 21 Pete 579. The last 4 trailers I have picked up, the rear upper marker lights aren’t working. Within the last month the green power cable has been replaced. Could the problem be a bad fuse or a bad pigtail on the truck side? It seems ridiculous to assume that so many trailers in a row would have bad lights.
  3. Deere hunter
    2,121
    10,022
    Aug 5, 2017
    Shallowater Texas
    Take a test, light and test your pigtail off your truck. The trailer lights will be the top left and the top right the very top one will be your ground. If one's not working that's your problem, and it's probably a fuse.
    Siinman Thanks this.
  4. abyliks
    abyliks Road Train Member
    4,114
    9,682
    May 2, 2010
    ludlow MA
    Check fuses There should be a different circuit for upper clearance lights
    Siinman and 25(2)+2 Thank this.
  5. tscottme
    tscottme Road Train Member
    On my Volvo, those upper rear, middle marker lights being out always meant a bad Trailer Marker LT fuse was burnt.
