Does anyone know if the torque rods on a 1999 vnl can be rebushed? And what determines whether a torque rod can be rebushed? Best I've heard, its more or less arbitrary.
Rebushing gen 1 vnl torque rods?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Appalachian_Soul, Mar 23, 2026.
First thing to find out is if bushings are even available. Then ask if the whole rod with bushings is available. It's going to be faster and easier and probably not much more expensive to just replace the rod. Have you replaced bushings before? If not, then factor in paying the labor on top of the bushing price.Rideandrepair Thanks this.
- I went through that whole exercise 11-12 years ago. It wasn't worth my time and effort-or $ to pay for the labor-to rebush. You have to press the old bushings out, maybe clean the rod if rubber left behind, and press in the new bushings. You would at least need a shop press and an arbor, like maybe a big socket. Or I imagine a specialty tool like a Tiger tool would work too. But, unless you have that equipment, at the time those tools cost more than the torque rods.
JB7 Thanks this. -
I just changed the whole arm on my Freightliner. Each axle and the cab. Can be a bit tricky lining up the bolts. Wood blocks between the frame and inside of drive to keep axle from shifting. Big bottle jack. It’s doable. It’s a common part. I think I bought mine in stock at Truckpro.
