Recommendation for starting your career
Discussion in 'Questions From New Drivers' started by All-American82, Feb 9, 2013.
  1. All-American82
    All-American82 Medium Load Member
    302
    179
    Jan 27, 2013
    Rogersville, AL
    Hi!
    This is a question for Trucking veterans. Would you recommend STARTING your career in Flatbed or Tanker. Not so much one over the other. Just in, fresh out of school, would these be ok choices?
    OR should I get experience in some other part of the industry first, then go for those. It seems you have more to think about ( tarping, wide load, load shifting, etc... ).
    Just asking as I seem to be leaning more this way
    Any advice is appreciated !
    "All the Way"
  3. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    You will do more physical work with a flatbed with load securement etc... I first drove in the Army and we not only had that, but sideboards to deal with too LOL.
    Tankers, especially food grade that don't have baffles is a different type of driving with the surge.
    My suggestion.of the two options would.be flatbed for a Beginner, but others may feel different.
    All-American82 Thanks this.
  4. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    My boyfriend said flatbed then you know what work really is,lol.You build muscle you lose weight.You learn more about securing a load in flatbed then anything else.Tanker comes the slush factor unless you haul dry bulk.
  5. Milktanker
    Milktanker Medium Load Member
    373
    252
    Jun 25, 2012
    Frenchtown, mt
    I started out pulling milk, pulling a tanker has very unique challenges to it. You really have to be able to visualize what that liquid is doing behind you. I've watched more than one new driver blow a driveline or rear end from timing the slosh wrong and hitting the gear right when the wave hits one end of the trailer. Unless you are very confident in your driving I would go flatbed first. There are a lot more variables to think about when pulling liquids.
  6. pattyj
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    I haul tanker as well as swinging meat and with tanker I do get nervous.You can really feel the trl sway if you don't drive smooth enough.
  7. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    55,036
    Dec 8, 2012
    hunting...../ retired
    All good advice...to the OP, if you can get your 1st tier of experience in a van or reefer. That will give the basics of the equipment, , keeping a good line going down the road, passing, descending a grade , parking , backing, the feel of a heavy load , shifting , (double clutching), turning, all the things you need to get down pat to be a safe productive driver. Then after a couple of years, move on to the tanker or flatbed areas if you want. Each one of those has its own set of variables and dos and don't s.....best to learn to walk, then trot, then run...Good Luck
