Red engine light on and beeping
Discussion in 'Kenworth Forum' started by Factransport, Jul 26, 2013.
Page 2 of 2
Get a mechanic to hook up to your trucks ecm. It should tell him what is causing the problem.
I took it to cat dealer they hooked up to it but no codes showed fine
Is there a manual way to reset it
You might disconnect the battery cables, wait a few minutes and then reconnect.
How is your oil pressure?
Oil pressure good oil temp bout 200. Everything checks out. That's why I'm confused
Are you sure that it is your engine? You mentioned in an earlier post about your air pressure. Are you certain that it is your engine light and buzzer? Does the light and buzzer go off when the air builds?
Good air press. N light stays on. N yes it's the red engine light.
Page 2 of 2
