Refrigerator power supply
Discussion in 'Freightliner Forum' started by tltransportation, Jan 15, 2012.
  1. tltransportation
    tltransportation Bobtail Member
    Montana
    Does anyone know where the power supply comes from for the refrigerator? Can't trace it back to see if another fuse is blown or what?
  3. bandit137
    bandit137 Bobtail Member
    6
    Jan 9, 2011
    St Petersbueg, Fl
    i have the same issue. Asked the tech at the TA after checking my fuses. He suggested bite the bullet go to dlr and they will find it fast. you save on goose chase time.
  4. stlwaco
    stlwaco Light Load Member
    276
    47
    Oct 4, 2009
    St. Louis, MO
    What year and model truck? The centuries and columbia have driven recently have the power coming from the panel behind the driver seat belt.
  5. oc83baker
    oc83baker Medium Load Member
    410
    127
    Jan 18, 2011
    all 48
    05 columbia
    I'm having the same problem mine went out today, I will check that panel see if I find the fuse. When I got the truck the power outlet in the tv storage didn't work so I run a wire from the refrigerater outlet to the tv out. The original wire for the tv outlet run behind the cabilets and I didn't want to move them to trace the wire.
  6. 25(2)+2
    18,762
    46,074
    Sep 18, 2006
    the road less travelled
    08 Columbia, all the power outlet fuses are behind the driver's side door. I doubt there is much difference there. Should be labeled.
    The lighter fuse is on the dash under that cover, it is marked.
  7. oc83baker
    410
    127
    Jan 18, 2011
    all 48
    I check in that panel nothing is labeled. The wires at the outlet are grey but inside the panel is one big black wire with about 6 fuse on it, I check all of the fuse the 3 blue fuse live on both side with the truck off, the 3 pink fuse were dead on both side
  8. oc83baker
    410
    127
    Jan 18, 2011
    all 48
    I found the fuse panel, I had 2 blown fuse inside, replace them and the out let on the left and right work. Thanks y'all
  9. robsraintouch
    robsraintouch Bobtail Member
    Im haveing a hard time finding the fuses for the TV and power supply in my 2004 Freightliner Columbia can you tell me where you found the two fuses that where out thank you for your help.
