Refused employee verifications
Discussion in 'FFE Lisa American Eagle' started by JPenn, Dec 31, 2013.
  1. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    Any other former FFE drivers out there who left before KLLM took the reins having trouble applying elsewhere due to KLLM/FFE refusing to verify employment? A former coworker and I have both run into this, with KLLM staff basically telling us that they will not verify past employment. They're spicing it up a bit though, giving the impression that they could, but they're extending the middle finger instead. Also, someone has very specifically mentioned that they won't "do anything for you pain in the a.. Northeast drivers".
    Nice. Any of you who stayed on, wish ya luck with these clowns.
  3. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Wonder why they would do this.Some employers will take a recent check stub for proof.
  4. G/MAN
    G/MAN Road Train Member
    7,031
    8,624
    Sep 3, 2010
    If you have log books, check stubs, settlement sheets or even a letter from your former dispatcher would work.
    bullhaulerswife and pattyj Thank this.
  5. JPenn
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    I've got logs, pay stubs, direct deposit records, etc. I'm also planning on getting a copy of my DAC/hire right/whoever they are now report. My coworker isn't so lucky, his ex threw all his stuff out. It's just strange to me that they would be as antagonistic as they are.
    Anyone currently there and thinking of leaving, save all supporting documentation just in case it isn't just us Northeasters they have a problem with.
    J424b Thanks this.
  6. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    This burns me up along with recruiting tactics.
    Drivers, megas use DAC so your records are there, and you have pay stubs and I hope log books for the tax man. That should do it......
    As far as I know only the HIRING carrier must attempt to verify your past. A response from the former is not law if the carrier retains proof of attempting to verify. I'll hit the books and see if I can pin it down.......
    One of the reasons KLLM is pissed is ...you were bought...indirectly. Seated trucks are a part of the negotiated price...so they bought a seated truck that will now become unseated.......
    It's amazing how carriers just don't get it..........
    JMO
  7. markealy
    markealy Road Train Member
    1,223
    1,301
    Jun 20, 2013
    EL PASO
    That's a shame kllm was a awesome place to work drove a million safe miles there is Jim Richards still running the show
  8. chalupa
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Here you go:
    Subpart C - Background and character
    [h=3]§391.23 Investigation and inquiries.[/h] Question 1: When a motor carrier receives a request for driver information from another motor carrier about a former or current driver, is it required to supply the requested information?
    Guidance: Generally no. See §382.405, however, for requests pertaining to drug and alcohol records.
    Question 2: May motor carriers use third parties to ask State agencies for copies of the driving record of driver-applicants?
    Guidance: Yes. Driver information services or companies acting as the motor carrier’s agent may be used to contact State agencies. However, the motor carrier is responsible for ensuring the information obtained is accurate.
    JPenn, pattyj and Criminey Jade Thank this.
  9. Criminey Jade
    Criminey Jade Road Train Member
    1,609
    1,803
    Aug 16, 2013
    Not Colorado Anymore
    Wouldn't checking HireRight mean your driving employment is verified?
    Did they say they are using TheWorkNumber.com? I have a couple of past employers who will flatly refuse to verify employment. I indicate the URL and employer codes on the application, but that's about all I can do.
  10. chalupa
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    And:
    [TABLE="align: center"]
    [TR]
    [/TR]
    [TR]
    [TD="colspan: 3"][/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD][TABLE="class: leftNavAndContenttable"]
    [TR]
    [TD="class: contentarea, colspan: 2"][TABLE]
    [TR]
    [TD][TABLE="align: center"]
    [TR]
    [TD="width: 100%, colspan: 2"]Subpart D - Handling of test results, records retention, and confidentiality
    Code of Federal Regulations§ 382.405Access to facilities and records.(a) Except as required by law or expressly authorized or required in this section, no employer shall release driver information that is contained in records required to be maintained under §382.401.(b) A driver is entitled, upon written request, to obtain copies of any records pertaining to the driver's use of alcohol or controlled substances, including any records pertaining to his or her alcohol or controlled substances tests. The employer shall promptly provide the records requested by the driver. Access to a driver's records shall not be contingent upon payment for records other than those specifically requested.(c) Each employer shall permit access to all facilities utilized in complying with the requirements of this part to the Secretary of Transportation, any DOT agency, or any State or local officials with regulatory authority over the employer or any of its drivers.(d) Each employer shall make available copies of all results for employer alcohol and/or controlled substances testing conducted under this part and any other information pertaining to the employer's alcohol misuse and/or controlled substances use prevention program, when requested by the Secretary of Transportation, any DOT agency, or any State or local officials with regulatory authority over the employer or any of its drivers.(e) When requested by the National Transportation Safety Board as part of an accident investigation, employers shall disclose information related to the employer's administration of a post-accident alcohol and/or controlled substance test administered following the accident under investigation.(f) Records shall be made available to a subsequent employer upon receipt of a written request from a driver. Disclosure by the subsequent employer is permitted only as expressly authorized by the terms of the driver's request.(g) An employer may disclose information required to be maintained under this part pertaining to a driver to the decision maker in a lawsuit, grievance, or administrative proceeding initiated by or on behalf of the individual, and arising from a positive DOT drug or alcohol test or a refusal to test (including, but not limited to, adulterated or substituted test results) of this part (including, but not limited to, a worker's compensation, unemployment compensation, or other proceeding relating to a benefit sought by the driver). Additionally, an employer may disclose information in criminal or civil actions in accordance with § 40.323(a)(2) of this title.(h) An employer shall release information regarding a driver's records as directed by the specific written consent of the driver authorizing release of the information to an identified person. Release of such information by the person receiving the information is permitted only in accordance with the terms of the employee's specific written consent as outlined in § 40.321(b) of this title.
    [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [/TR]
    [TR]
    [TD="colspan: 3"] [/TD]
    [/TR]
    [/TABLE]
  11. JPenn
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    Oh I haven't worked there since August, and my coworker quit 3 months prior to that. I find it somewhat unbelievable that all of FFE's records have vanished into thin air, especially since they still owe me a W2.
    Edit. We both have our own trucks and are in the process of taking them to Mercer. Just by way of explanation....
