Regen issue
Discussion in 'Volvo Forum' started by Tbones80, Apr 13, 2021.
  1. Tbones80
    Tbones80 Bobtail Member
    Hello, I have a 2015 Volvo d13. It's asking for a parked Regen almost daily. Has an all new def system, including pressure differential sensor and doser.
    It never gets to active Regen. I can watch the soot level gauge go from nearly empty to level 2 in a heartbeat after about 6 hours of highway driving. Just boom full.
    I was thinking soot level sensor, as I've already done the pressure differential.
    Also maybe another related problem, cab low voltage alarm going off randomly. Smack the dash by the radio and it turns off every time. Checked all the wiring back there but can't find nothing. Thinking it might be the actual radio going out and drawing too much voltage. But the Regen issue is what's really bothering me right now.
  3. Inderjit
    Inderjit Heavy Load Member
    772
    737
    Sep 17, 2017
    How many miles on the particulate filter? Over time they fill with ash and require
    more frequent regens. It may need to be baked or replaced.
  4. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    Could be many things really. Check the seventh injector behind the turbo. Also could be face plugging from the DOC (Diesel Oxidation Catalyst). It could be that your heater box is failing requiring it to need more regens.
  5. Cattleman84
    Cattleman84 Road Train Member
    10,031
    71,683
    Nov 1, 2017
    The Sticks, Idaho
    I had a 2014 Volvo do that to me... When we pulled the DPF it was almost completely plugged. Put a brand new DPF in amd it fixed the problem... The plugged DPF was so bad that even baking wasnt an option, it was toast.
