Regen light!!
Discussion in 'Ask An Owner Operator' started by Ddeleon444, May 17, 2019.
  1. Ddeleon444
    Ddeleon444 Bobtail Member
    5
    May 17, 2019
    My international pro star 2011 asked for a regen. I drive mainly highways. I regened fully for over an hour 3 times today and the light won’t turn off. Also I’ve had an upside down yellow triangle on for a couple of weeks but was told that it goes on all the time. Any thoughts?! Please help
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    157,718
    Definatly something wrong with the dpf.. Probably needs changed out/cleaned.. I got the same problem in my cascadia, need my dpf changed out , threw check engine and emissions codes at me right after i left the house...i would take urs to the shop asap.. A regen 3 times a day is not normal at all
  4. Ddeleon444
    5
    May 17, 2019
    I bought her just a few weeks ago and this is the first time she asks for that. I did it just in case but the light never shut off. It would regen though. How much will that run me do you think?
  5. D.Tibbitt
    157,718
    A cleaning will cost anywhere from $500 -$1500. If it needs to be changed i have heard of guys paying 10k+ to get a new dpf... I would get a second opinion , im not a mechanic by any means , there alot more guys on here that know more about it then me but i would guess it just needs to be cleaned out
  6. Ddeleon444
    5
    May 17, 2019
    Thankyou for the reply! I’ll take her to the shot first thing in the morning
  7. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    what is the code showing for the light...??
  8. HillbillyDeluxeTruck
    5,964
    30,523
    Mar 3, 2013
    San Antone
    Maxxforce engine huh...
    You should have really done better research before making that purchase because that truck/engine is going to bankrupt you. Yes, Im serious. If the truck is needing multiple regens a day, your dpf is clogged and no amount of regens will fix it. An International dealer will charge you approx $3000-5000 to replace the filter and components. Then the new components will fail and you'll be stuck again.
  9. flood
    4,169
    4,051
    Dec 25, 2010
    could be lucky and just be the injector.....
  10. Flat Earth Trucker
    4,342
    16,815
    Nov 19, 2018
    If you're in Texas, DON'T take your truck to SanTex in San Antonio. Horrible customer service. I spent eight days waiting for an oil leak fix.
  11. snowwy
    snowwy Road Train Member
    20,616
    13,335
    Jul 6, 2009
    Call before taking in. Not everyone has a cleaning machine.
    The FL dealer in Vegas sends them out to be cleaned while the FL dealer in Salt Lake has a machine. Vegas was a 4 day repair while Salt Lake can do it in 1 day.
    Granted you're talking about a International.
    The 09 T660 I think it was. Cost $4500 when it got a new filter.
