Reliable crimp connectors
Discussion in 'Trucks [ Eighteen Wheelers ]' started by leftlanetruckin, Jun 8, 2014.
  1. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Just saw a thread where butt crimp connectors were criticized.
    These are what I use for motor swap engine wiring harness'. I have found that it is every bit as reliable as a soldered connection (duh), but quicker and ultimately stronger when vibrations and bends are present. Never had a problem when making wiring harness' stand alone for motor swaps, shortening OEM harness', and so on.
    http://www.cableorganizer.com/multilink-butt-splices/
    Just throwing it out there, as I had never heard of them until a few years ago.
    Martin
    rank and heavyhaulerss Thank this.
  3. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    leftlanetruckin and rank Thank this.
  4. Ezrider_48501
    3,845
    5,134
    Apr 2, 2011
    bismarck, nd
    the adheasive lined shrink crimp connectors are the only type of crimp connectors i will use otherwise its solder rtv adhesive and heat shrink.
    rank, leftlanetruckin and milskired Thank this.
  5. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I use the ones that Fastenal sells, they are the best price I have found for a quality connector. They are the heat shrink kind that the inside melts a bit and oozes out as it shrinks down, have never had one of these fail.
  6. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    I use the ones from Fastenal also but on top of that, I also coat the entire thing with liquid tape to further seal the connections.
    rank Thanks this.
  7. Lucar
    Lucar Road Train Member
    1,396
    891
    Aug 22, 2012
    Texas
    Any butt connector that has the clear plastic either bluish (which is for cable up to 12 gauge from 18 ) can be shrunk.
    Pinkish which is best for 16 or 18 gauge.
    Yellowish for 14-12 gauge.
    The butt connectora with the solid colored plastic break whenever they're crimped.
    Get a lighter and rub the flame on these clear connectors after crimping and the ends will shrink. Good to keep moisture out, I personally roll tape like a mofo over it, we all know how bad our trucks fight the elements and for how long.
    rank Thanks this.
  8. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    I use them all the time
  9. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    This truck I bought is littered with those hard blue plastic ones. I kid you not when I say that every non factory connection has them. And it seems the previous owner had lots of connectors but very little wire because it's common to see 3-4 of them in a 12" length of wire. I replaced 14 this weekend and probably 50 before that. Ugh.
  10. KSC5386
    KSC5386 Bobtail Member
    Oct 14, 2012
    Maryland
    Dont kid yourself, I see trucks daily that " were just fixex by another shop" and they are littered with no shrink connectors. Or my favorite, twist the wires together and tape.
    I have always used the heat aheink crimp style and never had a problem. Many fleet trailers and trucks I DOT and connectors are solid years later.
