Removing cab horns from W9
Discussion in 'Kenworth Forum' started by mile marker 27, Dec 9, 2019.
  1. mile marker 27
    mile marker 27 Road Train Member
    Dec 4, 2019
    1,335
    Thanks Received:
    1,694
    horns no longer work on my B model and was wanting to remove them anyway, for a cleaner look. There two 10mm head bolts that hold them to the top of the cab, from the outside. Assuming the whole headliner has to come down, are there any hidden screws that hold the headliner up? Don’t want to tear the HL up, to do the job.
  2. Rubber duck kw
    Dec 9, 2017
    6,092
    Thanks Received:
    17,686
    Should be nutserts on the inside that "should" allow you to turn just the bolt.
  3. mile marker 27
    Dec 4, 2019
    1,335
    Thanks Received:
    1,694
    The air supply line will have to be unthreaded from the bottom of the horn. I tried lifting it from on top of the cab but it wouldn’t lift high enough to unthread it. Lines will also have to be plugged. Thought there might be some screws under certain buttons on the HL.
  4. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,837
    ga
    Some of the old ones you must pull the door seals from top side and find screws that hold headliner in and will be a bear to get out?
  5. bigguns
    bigguns Road Train Member
    Jun 13, 2013
    2,846
    Thanks Received:
    6,854
    Omega,GA
    The air line. Pull it up as far as possible and cut it off. Then pull the air line down through the window post or fish it out of the dash from behind the left gauge panel. Worse comes to worse you will need to drop the headliner.
    mile marker 27 Thanks this.
  6. tommygun58
    tommygun58 Light Load Member
    Sep 22, 2015
    88
    Thanks Received:
    61
    East Texas
    My 99 w900l has about 8 screws. Once you take the trim down, you can pull a little down on the edges and you can feel the buttons that are solid. The buttons will snap off and hide the screws. My girl friend helped hold it up when you get to the last few screws.. good luck.
  7. w9l
    w9l Medium Load Member
    Oct 12, 2013
    316
    Thanks Received:
    514
    I removed my horns on my '93 and added 4 more clearance lights. Actually put 9 new led lights on it. I ran the air lines from the horn valve back down the window post and rearward to my train horns mounted on the inside of frame and turned down. Works great for me. Have the post and lever valve in a 379 and I get seatbelts hooked on it pretty often. Yes the buttons pop off in several places in headliner and conceal screws. Pretty easy job.
  8. mile marker 27
    Dec 4, 2019
    1,335
    Thanks Received:
    1,694
    I’ve got lots of buttons any ideas on which one are THE ones that are hiding the screws?
  9. w9l
    Oct 12, 2013
    316
    Thanks Received:
    514
    I will look and see when I get home (likely this evening ) and report back.
  10. tommygun58
    Sep 22, 2015
    88
    Thanks Received:
    61
    East Texas
    Just pull down a little after you remove the trim. You will be able to figure out wich buttons are solid. Those will pop off, hiding the screws..
