Reoccurring DEF problem - Freightliner 2013 DD15
Discussion in 'Freightliner Forum' started by Mike A, Mar 21, 2019.
  1. Mike A
    Mike A Bobtail Member
    8
    I have a 2013 DD15 Freightliner truck. I've been in and out of the mechanic shop now for 3 months, with the same DEF problem. Check engine light comes on and codes giving me - low NOX conversion and bad quality DEF. I finally went into the Freightliner Dealership and changed my DEF filter gasket and pump flushed out all the old DEF and had new DEF put in until it ran clear. Afterwards had additional testing done and all codes cleared. After spending $4400, the very next day the same codes and engine light came back on after doing 100km/hr steady and stays on after that.
    Does anyone know what the cause of this is or how to fix this reoccurring problem??
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I know what is the problem. Ready to pay $500 ? :)
    roshea Thanks this.
  4. Mike A
    8
    Pls help. What do you think the problem is? I've already spent $7,000 on this problem!
  5. kubasj05
    kubasj05 Light Load Member
    148
    57
    Apr 18, 2013
    He means if you're ready to kiss Def system bye bye for $$$. This subject can't be discussed on here
  6. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I mean I know what is the problem. I will not suggest him DPF/SCR delete. :)
    rachi and roshea Thank this.
  7. kubasj05
    148
    57
    Apr 18, 2013
    My bad:banghead:, however I don't mind deletes, no hard feelings though:angel4:
  8. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    1. DEF pump bladder has not enough air or over pressured.
    2. Inlet NOX sensor is slow / shows lower value (most likely fault)
    3. Engine has 650k plus miles 1 box could be bad.
    4. Outlet NOX sensors slow /shows higher value
    5.Def pump sucks air while vehicle in motion ( vary rare problem but happens).
    The truck was in the dealer and I am sure they have done DEF quantity test and it was ok. Sometimes during parked regen or SCR performance test NOX conversion is ok but when you drive the truck 4364 code pops up. I had similar situations many times and fixed by replacing one of NOX sensors...
  9. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    ^^^^ He's correct. Drifting (intermittent) bad outlet Nox sensor is the usual cause for 4364. Have to have patience and watch the laptop screen the whole time during the regen and that bad sensor value will start jumping around. Have to pay attention because it will often go back to normal numbers.
    Motto, rachi, shatteredsquare and 3 others Thank this.
  10. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Completely agree, just want to add.
    1: have seen this once, proper amount of nitrogen can make a difference.
    2: this is the most common problem found in the fleet I woork on. The tech needs to know to watch for the spike in the beginning, and also what numbers they should register when they level out ( trouble shooting doesn’t give these numbers).
    3; the only times I’ve seen the onebox (SCR side) fail is when soot has passed the DPF filters and coated the SCR. If there’s black in your stack this could be possible. Last check a one box (with help of fleet pricing and “help” from Detroit) was $7000 plus labor.
    4: re-read #2
    5:i’ve Never seen this, but I do believe it.
    One more thing I want to add to the list. I have seen a couple times a buildup of crystallized DEF at the injector in the one-box and the injector tip plugged off and not spraying.
    Tip of the day,
    If you suspect a bad onebox, and you have any engine warranty left, get an injector to fail before you take it in to the shop, if an warrantable engine issue (injector) fails and craters the one-box, warranty will pay for it.
    rachi, D.Tibbitt, NorCenArk and 4 others Thank this.
  11. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    Thanks for additions.
    about #3. in 80% cases no need to replace 1 box if it is soot coated. Just install new dpfs, let outlet nox sensor sniff air and drive 10000 miles. )))) put back NOX outlet sensor and you will be surprised. Fixed more than 5 units.
