REPAIR HELP PLEASE!!!
Discussion in 'Ask An Owner Operator' started by Neverquittrucking228, Oct 14, 2022.
  1. Neverquittrucking228
    Neverquittrucking228 Light Load Member
    108
    52
    Feb 23, 2021
    Hello guys I have an issue with my leaking air where the exhaust manifold & turbo gasket meets. Just had may turbo gasket replaced bc it was bad but it didn’t help any so the guy at the shop said I’ll have to replace my turbo & exhaust manifold if I wanna fix the problem correctly! It’s a hairline crack but it’s there. My question is can I have this welded rather than having to replace these expensive items?
  3. AModelCat
    164,921
    Cast iron = no weld. It'll never hold.
  4. Neverquittrucking228
    108
    52
    Feb 23, 2021
  5. Neverquittrucking228
    108
    52
    Feb 23, 2021
    Cummins isx engine not sure if that matters! Mechanic says he might have a used one that fits but not sure if that’s even worth a try any advice would be appreciated
    Boondock and Rideandrepair Thank this.
  6. Mcast3092
    Mcast3092 Light Load Member
    137
    107
    Jul 31, 2018
    If it’s making you money invest in it. Just fix it when you can
  7. rch10007
    rch10007 Medium Load Member
    560
    860
    May 26, 2007
    Madison, AL
    I'd take it off and take it to a local welder or machine shop. It can be welded, but you want someone who knows how.
  8. Brandt
    Brandt Road Train Member
    4,632
    6,368
    Sep 17, 2012
    Pittsburgh Power has new ones not I believe they port and polish the inside. So you can get more power maybe better MPG. They are better then the factory ones.
    Manifolds
  9. abyliks
    abyliks Road Train Member
    4,138
    9,743
    May 2, 2010
    ludlow MA
    Take it off and throw it away
    full tilt will be about the same price as oem and drop egt a few degrees
  10. Ridgeline
    22,741
    123,666
    Yeah it does, it has to be done by someone who knows how to do it right.
    I had several cast iron components welded, not one failure.
  11. Neverquittrucking228
    108
    52
    Feb 23, 2021
    Thanks for the reply’s guys! I’m gonna try and find a good welder in my area
