Replace Air Regulator???
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wjhuskey, May 15, 2024.
  1. wjhuskey
    wjhuskey Bobtail Member
    43
    15
    Nov 1, 2014
    Hello guys. I have a 1993 Peterbilt 379 project truck and it's been setting for a couple years but finally getting around to working on it. The brakes have always made a steady "air horn toot" sound as soon as you press down on them (not the usual air sound when letting off). When I started it the other day, I noticed the air compressor regulator/governor on the side of the engine was spewing air. The truck has always had trouble building air. I plan to pick up a new regulator in a couple days. Could this be why the brakes have always made this sound?
    If not, what should I check? A valve???
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,430
    6,467
    Aug 26, 2014
  4. Sm0kie
    Sm0kie Bobtail Member
    8
    May 15, 2024
    Doubtful. In my experience older trucks just do that. Might be style of chambers you have
    Diesel Dave Thanks this.
  5. wjhuskey
    43
    15
    Nov 1, 2014
    I've got 2 other trucks this age (another '93 and a '92), neither make this sound with the brakes
  6. RocketScott
    RocketScott Medium Load Member
    579
    946
    Apr 10, 2013
    Kentucky
    Mine's an '89 and doesn't make that sound. Probably a relay valve sticking or a tear in one of the chamber diaphragms
    BoxCarKidd Thanks this.
  7. BoxCarKidd
    4,430
    6,467
    Aug 26, 2014
    Two people to chase the noise would help.
  8. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    I would think it would be the air blowing out of one your exhaust ports. Either the service valve or your foot valve. Like BoxCarKidd said. Two people to chase it down.
  9. wjhuskey
    43
    15
    Nov 1, 2014
    The sound is definitely coming from behind the dash at the park brake valve area.
  10. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    The noise happens when you mash the brake pedal and it comes from inside the dash?
  11. wjhuskey
    43
    15
    Nov 1, 2014
    Yes
