Replace this strap?
Discussion in 'Flatbed Trucking Forum' started by gravdigr, Sep 5, 2012.
  1. gravdigr
    gravdigr Road Train Member
    1,210
    1,121
    May 2, 2011
    Hollidaysburg, PA
    So I was rolling up my 4" straps after getting unloaded today and found this. Would you replace this strap? Is it still legal? I already bought a new strap anyway because I don't take chances. Sadly this is maybe a foot from the hook so I can't cut it off. Any creative uses for damaged straps? Cut it up for corner protectors?
    CAXPT Thanks this.
  3. lonelyswmtrucker
    lonelyswmtrucker Medium Load Member
    612
    248
    Sep 14, 2011
    down the bayou
    i certainly would replace it & like u asked, cut it up & use for corner protectors; i wouldn't leave anything to chance with securement
    CAXPT Thanks this.
  4. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    if checked closely enough it would be cut and frayed, replace it, but keep in case you absolutly have to use it. and it can bu used for protection and to make a set of vee-boards
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,046
    May 13, 2011
    Middle Tennessee
    1/4" is all you are allowed. If you have a heavy duty sewing machine you can make a shorter strap.
  6. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    Take it to a tarp/canvass repair shop they will/can cut off the bad part and resew it around the hook. Then I would keep it for a spare.
  7. Cab Lizzard
    Cab Lizzard Light Load Member
    118
    45
    May 16, 2011
    MIA
    If your driving an International they work well to cut the Squeak out of the hood.
    Place a length of strap where the hood meets the cab bumpers.
  8. gravdigr
    1,210
    1,121
    May 2, 2011
    Hollidaysburg, PA
    Hey Thanks! I happen to have family that does awnings and such. Will it keep it's WLL rating if it's repaired? If anything I can use it to hold down my chain box or rolled tarps on the bed if it's repaired.
    CAXPT Thanks this.
  9. KANSAS TRANSIT
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    The repair shop will be able to tell you if their machine sticth PI enough to keep the rating, I'm sure that most if not all can. And your right, I always seem to need at least one strap that is "non-stress" for holding incidentals.
    Stan
    CAXPT and RedMack Thank this.
  10. justsayin
    justsayin Bobtail Member
    Sep 6, 2012
    If the strap is repaired,make sure the limit tags are still on it. In fact make sure the tags are on all your straps. The DOT loves to check for them.
  11. -insert name-
    -insert name- ATM squishier
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
