Replacing 2004 D12 accessory drive and fuel pump.
Discussion in 'Volvo Forum' started by silver dollar, Jan 26, 2021.
  1. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    Greetings. I’m getting a low fuel pressure fault and I want to change the fuel pump and accessory drive. There’s a local shop nearby that works on Volvo’s, but it will be more than a week before he can get to it. I’m thinking about tackling it myself this weekend
    About how long should it take to change them?
    Anyone have any tips on what to do and what not to do?
    Any information you can offer will help and be greatly appreciated. Thanks
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Need to remove fan blade.
  4. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    alternator and fuel lines both engine belts, need 12mm socket 14mm and t45 Torx, possible remove power steering pump if mechanicaly savy shouldn't take more than 4 maybe 5 hrs
    silver dollar Thanks this.
  5. silver dollar
    481
    210
    Jan 31, 2009
    Thanks. Does it matter which unit is removed first?
  6. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    it does not but easier to remove accessory and than pump and install first pump than accessory just make sure you do not force anything in, also one of the bolts for the accessory is also holding pump and screwed on from the back.
  7. silver dollar
    481
    210
    Jan 31, 2009
    I got everything tore apart today. I found some play in the drive and the pump shaft was really worn bad. Can you tell me if the pump bolt holes are open to the oil cavity? I ask this because there was like silicon sealer in the holes as if someone was sealing them from oil.
  8. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    they are not open to any oil cavities and whoever put them on before did that not necessary to do and never have done this before.
