Replacing a alternator on N14
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DieselHooker, Nov 23, 2020.
  1. DieselHooker
    DieselHooker Bobtail Member
    Nov 23, 2020
    I recently purchased a 97 9400 with a N14 Cummings from a younger guy. He had tried to get it running ( few crappy batteries and a delco alternator ) When I got it home ( wouldn't run on its own , only gas rag ) I replaced the batteries and the fuses next to the ECM. That got her going but now she's having issues with the charging system. When I replace the batteries , I also had to wire them correctly ( kid doesn't quite know what he's doing ) Now I'm thinking he also wired the alternator incorrectly as well. This is my first N14/Cummins and I do not want to play the guessing game. Could someone please either take a picture or explain who/what/where's for the correct way to place the wires on a Delco 24si ? Also noticed from others that I should have some kind of fusible link coming off it as well. Any insight on N14's would be appreciated!
  3. God prefers Diesels
    4,198
    22,262
    Jun 26, 2020
    South Texas
    This is on my ISX, but it's a 24SI.
    Heavyd Thanks this.
  4. DieselHooker
    Nov 23, 2020
    I'm not sure but I do believe it has to be the N14. I'll take a closer look with your picture. Thank you!
  5. God prefers Diesels
    4,198
    22,262
    Jun 26, 2020
    South Texas
    There's some good mechanics on this forum, but @Heavyd pretty much has these Internationals memorized.
    Heavyd and tommymonza Thank this.
  6. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    I am away from my same year N-14 until tomorrow.
    I’ll snap a pic tomorrow and post it
    I just got my truck running after it sat all last winter.
    Bad fuse on the ecm power wire after I believe I accidentally grounded when disconnecting the batteries.
    God prefers Diesels Thanks this.
  7. tommymonza
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    Not going to make it back to my truck until 5 tomorrow. Just giving you a heads Up.
  8. DieselHooker
    Nov 23, 2020
    Thanks for the heads up! I'll keep an eye out for a update.
    tommymonza Thanks this.
  9. Steptank
    Steptank Bobtail Member
    7
    18
    Jun 29, 2017
    i have n 14. I just replaced my alternator about two months ago with a delco remy 24si. The old one was over 6 years old. Only has two wires to hook up. Positive out and negative out. Hope this helps 16062488502829099368937092412140.jpg
    Stray_Dog, Heavyd, tommymonza and 2 others Thank this.
