Replacing air hoses under the seat
Discussion in 'Freightliner Forum' started by AlexD13, Apr 11, 2023.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Hi, have a leaking hose under the driver seat. Not sure if Anyone has ever replaced it but wondering if its fairly easy?
  3. AlexR_uz
    AlexR_uz Bobtail Member
    19
    14
    Sep 10, 2019
    PA
    Are you talking about air line coming through the floor carpet towards seat or about seat air lines?
    If this standard Freightliner’s ISRI seat, move seat cushion forward to the maximum (only cushion, not the whole seat) and move it up while doing that. This way you will remove it and will have access to the all air lines under it.
    If your seat is International - you have to move it’s seating cushion also forward and pull it from the buck of the cushion.
  4. Jacoooooooo
    Jacoooooooo Heavy Load Member
    748
    1,054
    Oct 20, 2013
    What truck is it? Volvos have National Seat brand seats, you would need to figure out where it’s leaking and try to source replacement connectors, switches. It’s easy but you may end up needing to delete some adjustments to minimize number of connections down there if you don’t have parts - they are hard to come by. I just left height adjustment and lumbar, the rest is deleted for now.
  5. AlexD13
    298
    85
    Jun 13, 2016
    The part that broke off is the the height adjustor hose that connects to the valve
