Replacing cigarette lighter and aux plugs.
Discussion in 'Freightliner Forum' started by Opus, Jun 13, 2020.
  1. Opus
    132,297
    How?
    Mine in the front have both gone bad.
    I was thinking that you just pop them out and pull off the wires and put in new ones.
    Is this correct?
    Do you just pry them out?
    Appreciate it in advance
    2014 Cascadia
  3. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    I don’t know about Freightliner, but I’ve seen three types.
    Some have two tabs that you press in,then push the socket out. Another will have a clip holding it. The other has a nut on the back.
  4. Opus
    132,297
    Mine kinda look like you just pry them out.
    But you never know.
    I might need the 'special' tool
    062 Thanks this.
  5. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    My 2016 you just pry them out. When they popup about a 1/4" you will see the notch and cut out just lift it from there easy peasy
  6. 062
    6,329
    33,969
    Oct 20, 2013
    If they have the tabs on the back, you may crack the dash. @QUALITYTRUCK
  7. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    No worries there no tabs just yank them
  8. Opus
    132,297
    Ok....so you have to turn it until it lines up with the notch?
    Then what? A couple of wires to unplug and plug?
  9. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    When taking it out there is no aligning needed just straight up. When putting back in if you are using original replacement then yeah. There is one plug on back with 2 wires
  10. Opus
    132,297
    Cool.
    Thank you very much.
    It's a real PITA when nothing up front works and you have to charge your phone from the back.
    I appreciate it
    D.Tibbitt and InTooDeep Thank this.
  11. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    I hear ya there both my front ones went out too ran longer cords to the back till one of them burnt out too. I got the replacements from freightliner because it was better no rewire and fit right forget the price but wasn't bad got 4 because 2 were bad and kept a spare
    Opus Thanks this.
