Replacing fifth wheel air slide
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Dec 15, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I have a Holland fifth wheel that I need to replace the air slide cylinder.
    Do I need to remove the fifth wheel itself to do that job?
    Can someone give me an idea where the bolts are that I take apart to remove the cylinder?
  3. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    Shouldn't have to remove the fifth wheel
    Getting the pins out depends on the type of slider you have. Mine doesn't have levers, the plungers and cylinder are all inline. To get it out I rigged up some woodworking clamps to compress the springs. With the springs pulled back there is a dowel that falls right out
    They make a special tool but it's spendy:
    https://www.napaonline.com/en/p/TWRTFTLN2500
    Dino soar Thanks this.
  4. StrokerTSi
    StrokerTSi Medium Load Member
    532
    777
    Aug 28, 2016
    I just used a regular valve spring compressor for cars.
