replacing fog light bulb 670
Discussion in 'Volvo Forum' started by bucksnort, Jan 17, 2014.
  1. bucksnort
    bucksnort Light Load Member
    69
    39
    Jan 23, 2011
    Let's just say it's easier/faster or so I thought to change a burned out fog light bulb on the 670 I drive.
    Tried taking the front cover off with the 2 screws which did nothing. Are these adjustment screws?
    There is no access from the back like a headlight. What's the secret?
    Thanks
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
  4. NoCoCraig
    NoCoCraig Road Train Member
    2,604
    1,695
    Nov 7, 2010
    Chattanooga, Tennessee
    Is it different than the 780? Just replaced the bulb in mine. You have to undo the two bolts on the inside facing the radiator and slide the assembly out the front, then you just swap out the bulb and put it back in.
    flood Thanks this.
  5. bucksnort
    69
    39
    Jan 23, 2011
    It looks like you can swap out bulbs.
    My problem is how do you get the assembly out of the bumper?
    I loosened the two screws in the face of the foglight but it won't pull out of the bumper. Do I need to pry the housing out with a screwdriver after loosening the bolts?
    CondoCruiser Thanks this.
  6. bucksnort
    69
    39
    Jan 23, 2011
    I don't see any bolts on the back so the 780 must be different
  7. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Bolts are on inside, not back. And after you change bulb, make sure you adjust it. Those two bolts on the face of assembly.
  8. bucksnort
    69
    39
    Jan 23, 2011
    I'll give it a shot. those allen head screws on the face take forever to back out. Either that or the nut holding them in is stripped and the screw just spins when you back them out. You'd think you back out the screws and the assembly will pop right out. It is a Volvo I guess
  9. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Those are adjusting screws.
  10. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    maybe this will help
    sully91, Smellfunny, lmar712 and 3 others Thank this.
  11. bucksnort
    69
    39
    Jan 23, 2011
    I'll take a closer look. something about searching for ways to take something apart kneeling in the snow with temps hovering around 0
