Report a violation or not?
Discussion in 'Trucking Industry Regulations' started by chilibowl, Jan 17, 2018.
  1. chilibowl
    chilibowl Light Load Member
    183
    142
    Jun 28, 2013
    Houston Texas
    i picked up a trailer that needed brake pads and tires as well as a license plate lamp. All I was given at the pick up was trailer registration. I still needed a inspection report as well as trailer insurance. I took the trailer to Loves and had the lamp repaired and then the trailer inspected. The mechanic listed my brakes and tires as needing repair. I contacted my boss and showed him a pic of the trailer inspection. He said he didn’t trust Loves mechanics and would send me a trailer inspection from the home shop. So he wants me to load out with a false inspection report and the same equipment problems.
    MY QUANDARY:
    Do I take a chance of driving with bad equipment and keep my job? Or pull into the next scale house and make them aware of the false inspection and bad equipment and lose my job?
  3. dptrucker
    dptrucker Road Train Member
    4,704
    3,240
    May 14, 2012
    adelanto,ca.
    Don' take the trailer. Ask for another one. If you get Inspected at scalehouse, most likely be put old but fixed
    Tb0n3 and ladr Thank this.
  4. ladr
    ladr Road Train Member
    1,383
    15,431
    Apr 14, 2013
    GA
    Simple. Do not move the trailer with a load until it is repaired.
    Find another job.
    supremegod, Tb0n3 and CrappieJunkie Thank this.
  5. Pedigreed Bulldog
    7,737
    14,423
    May 7, 2011
    Not only would you likely lose your job, but that inspection will be on your PSP making it more difficult to land another one.
    supremegod, Dave_in_AZ and Chinatown Thank this.
  6. Chinatown
    Chinatown Road Train Member
    77,785
    184,688
    Aug 28, 2011
    Henderson, NV & Orient
    I'd go with it. I've done it before and I'd do it again.
    Getsinyourblood and 8thnote Thank this.
  7. ladr
    1,383
    15,431
    Apr 14, 2013
    GA
    I pull nothing loaded with bad brakes.
    supremegod, Aamcotrans and Tb0n3 Thank this.
  8. Chinatown
    77,785
    184,688
    Aug 28, 2011
    Yep, he'd get hammered good by DOT and probably get some personal fines too.
    AModelCat and Dave_in_AZ Thank this.
  9. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Doesn't trust the mechanics at Loves? Well ok then see if he trusts the DOT. If it was just an mt move right back to there shop to get repaired I might do that if was a fairly short distance but other that that no way. Do you need this job that bad, its your ### on the line.
    ladr and Tb0n3 Thank this.
  10. Concorde
    Concorde Road Train Member
    5,482
    19,490
    Jun 29, 2016
    West Melbourne Florida
    Definitely not plan B.
    "Needing repair" I'd have asked the mechanic if it is bad enough to be put out of service. If they said yes, I would have asked for it to be put in writing on the inspection / estimate.
  11. Dave_in_AZ
    425,475
    If you pull into a scale as a whistle blower kind of thing, your still going to get hammered for driving defective equipment.
    It doesn’t work that way. You could call the highway patrol before you move it, but I'm not sure how that would turn out.
    Notify your boss in writing of the defects. Email or text. Now your butt is covered, and you're protected from wrongful termination under STAA rules.
    Next, find a real company to work for.
    Bean Jr., scottied67 and otherhalftw Thank this.
