Reprogramming
Discussion in 'Volvo Forum' started by jaykelz7, May 26, 2018.
  1. jaykelz7
    jaykelz7 Bobtail Member
    14
    Just had reprogramming delete done to D13 for (off road)per say .Since done truck has good power and mpg.Problem is truck does not want to shift and engage into gears at stop or rolling.Also idling erratic.Also shivers hard when using engine brake. Showing faults of PTO and Parking brake.I was told by one programer that ecm,bcm&abs modules all need to be re-programmed.My tuner only did ecm.And now I'm experiencing these issues.Also seems to be making louder engine noise at overhead.Is over head adjustment required when doing this?
    Any one with any knowledge of this or what needs corrected? Pablo......Anyone??
  3. Trucker2211
    Trucker2211 Light Load Member
    94
    91
    Mar 3, 2015
    Sounds like it wasn’t programmed correctly and is now stuck in “limp” or “derate”mode or something. Even if one little parameter isn’t re-written the right way, the ECM will throw a fit. www.OTRperformance.com is supposed to have the best delete kits on the market. Maybe check them out.
    jaykelz7 Thanks this.
