Reservoir Replacement
Discussion in 'Ask An Owner Operator' started by J.S., Nov 16, 2025.
  1. J.S.
    J.S. Medium Load Member
    482
    214
    Jun 27, 2015
    Texas
    I got a small crack in the inlet. Very small. Seems I could use JB Weld and it would do the job. It seems the brass plumbing on the inside would prevent a major leak and would seal well. Is it a vapor thing that means the tank must be replaced? I’m considering the water focused JB weld or the high heat standard type annd sand either down? Any thoughts?
  3. Ridgeline
    22,727
    123,498
    Washer fluid, repair.
    coolant system, replace.
    86scotty and Siinman Thank this.
  4. W923
    W923 Road Train Member
    1,420
    4,400
    Feb 28, 2022
    Inlet to what?
    Diesel Dave Thanks this.
