Return fuel line leak-Wishful thinking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jeffman164, Feb 8, 2021.
  1. jeffman164
    jeffman164 Medium Load Member
    630
    587
    Dec 4, 2012
    12.7 Detroit. I have been losing fuel prime. Found leak in hose of fuel return line. Can a leak in fuel return line cause a loss of prime ? Wishful thinking that this can be the cause of losing prime?
  3. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    No. You could return that fuel to the ground, and the engine wouldn't care. But if that hose has given up, your other hoses are probably in bad shape too.
    lester Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Should be lots of info from the search block at top right. I however can not find things as they disappear.
    There is a check valve in the back of the head. I posted a picture of one set up in a hole on a step. Filled it with fuel. It drained out in an hour or so. Replaced the o ring in it. Good to go. Check the check valve in the fuel pro if you have one. Injector seals can also be a problem.
    Should be many posts about this to search.
  5. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Yes it will cause loss of prime. Supply and return fuel lines suppose to be under fuel level all the time and air tight. After gear pump in fuel system there is connection to return line with orifice to purge air bubbles back to tank. If fuel lines connections not tight fuel will flow back to the tanks. Depends how gear pump and check valve are worn it's can take hours or minutes.
  6. jeffman164
    630
    587
    Dec 4, 2012
    Previously replaced fuel pump and check valve. Just replaced return fuel line and pressurized tanks. Started right up and let run for an hour. Let sit for 24 hours and then it started right up. Still keeping fingers crossed that this was the fix. Going to replace all of the other fuel lines when warmer.
