Reverse light or license plate light ?
Discussion in 'International Forum' started by Chicagoalen, Nov 30, 2022.
  1. Chicagoalen
    Chicagoalen Bobtail Member
    26
    9
    Apr 11, 2016
    Chicago IL
    Last year I got 2018 LT625 sleeper from dealer and he did Inspection that passed.
    20 days ago I got another yearly Inspection from TA and truck passed.
    2 nights ago I got violation for that light from state trooper in Texas. This white led strip of light is always on. This light is always on since I bought truck
    He says that is reverse light and it should not be running all the time.
    Does anyone has the same lights and can tell me are those lights on all the time ?
    Pic is attached
    D.Tibbitt Thanks this.
  3. wichris
    wichris Road Train Member
    4,656
    9,727
    Jan 17, 2011
    Reverse lights. Just clip the wire, they're not a requirement.
    License plate light must shine down, not out
    mslashbar Thanks this.
  4. D.Tibbitt
    161,089
    Reverse lights are most definatly required
    Heavyd, kwswan, buddyd157 and 2 others Thank this.
  5. Chinatown
    Chinatown Road Train Member
    79,333
    192,865
    Aug 28, 2011
    Henderson, NV & Orient
    Super-glue a piece of red plastic over it.
    Crude Truckin' Thanks this.
  6. zodiacflyer
    zodiacflyer Road Train Member
    1,195
    3,175
    Aug 25, 2014
    Those other two "inspections" weren't very #### thorough were they? That is an equipment fault that can be seen from literally a mile away.
  7. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Don’t cut the wire, find the issue, either wired incorrectly or corrosion somewhere
  8. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    Those are reverse lights. They are absolutely required. They should not be on. The problem is the reverse light sensor. Basically when you put it in reverse a piece of metal pushes down a ball that completes the circuit to turn on the reverse lights. I replaced mine and it was about $25 on a peterbilt.
