revised post
Discussion in 'Ask An Owner Operator' started by KRAKAJACKJONSON, Aug 28, 2011.
  1. KRAKAJACKJONSON
    KRAKAJACKJONSON Medium Load Member
    344
    68
    Aug 24, 2011
    Clemmons NC
    A week ago i asked the question what motor so you want since you can't get a new cat. Most of you replied with old motors like 60 series or keep you old cat and stuff it with parts. What I really wanted to know was if you were buying a brand new truck today what engine would you go with. I realize that some motors like detroits can only be had in freightliners, would that cause you to buy a fright shaker to get that dd15 or dd16? Fuel milege is a concern but not the main one to me, most truckers lie about that anyway. If I have a truck that pulls really strong and gets 5 mpg I am satisfied. I hear volvo's ride like a dream but their motors are hard and sxpensive to work on. My gut tells me to go with cummins but isx has had more than their share of problems, egr and so on. Cummins requires you to run more rpm at 65 mph than my cat which was 1350 rpms at 65 to get the best fuel milege. I think cummins want you to run about 1450 at the same speed. Never been a fan of mack old or new so thats not even an option.
  3. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Well, my 2006 Cummins ISX seems to like 1350-1400 rpm, which with 3.42 diffs and .76 top gear tranny, rolling on 22.5 low pro rubber will generally get me a mid 7's year round avg mpg. That has me running between 62 and 65 mph. If I was getting the 5 mpg you would would be comfortable with, I would get rid if the truck. The difference of over $20,000 a year or more in fuel costs would be better spent on a truck that is going to get better mpg. Plus I just turned 750,000 miles on the truck. Still has UOA samples that look as good as when it had 300,000 miles on the engine. Will hold onto this one for quite a while.
    KRAKAJACKJONSON Thanks this.
  4. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    CHR, are you looking at new truck or used? If new, not nearly enough data on these new motors regarding reliability. And these new motors are all equally complicated. Volvo is leading the class on electronics reliability in the past couple years. They were ahead of the game years ago and had plenty of issues and learned through the school of hard knocks.
    EGR is a great example of wait and see. When these motors hit the market the issue was heat. The companies knew this and worked on it. But you had so many company trucks spec'd to run low 60's and governed that many of the issues did not get fixed. Then they are sold and some O/O runs them at 70 in 110 degree heat and a whole new wave of EGR issues pop up. Same issue just not addressed with a recall.
    So what is going to happen with these new motors? Who knows. But that is a lot of money for an untested product that could have you sitting in hotel room why un-trained mechanics try and figure it out.
  5. rollin coal
    rollin coal Road Train Member
    13,632
    28,018
    Mar 29, 2008
    TN
    A new glider Western Star or Pete with a 6NZ Cat all built to my specs truck and motor.
    BigBadBill Thanks this.
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    with my '06 EGR ISX in a '07 Volvo 780, with 13 and 3.55 and 24.5 LP, I have seen fuel mileages in the low 9's and once (with a tail wind) broke 10mpg running the flat valleys in California at 58 mph and about 1250. But I am always well under 70K gross. Overall I am in the low 7's, but I do run the higher speed limits as posted in the western states. Little idle time with an APU.
    If I had to buy a new tractor today, it would have a Cummins in it. I had previously run 60 series (the smaller 11 liter ones before they raised the speed limits) and a 3406E and C-15.
  7. KRAKAJACKJONSON
    344
    68
    Aug 24, 2011
    Clemmons NC
    Have heard a couple of people here talk about a 6nz but i don't know what that is so you will have to tell this dumb trucker so next time i will know.
  8. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    It was the first C15-it's usually in 2000-2003 trucks, although there are some 2003 trucks out there with the MBN serial # prefix, and some 2000 trucks with the 3406E.
