Revving engine before releasing clutch?
Discussion in 'Questions From New Drivers' started by ninehk, Aug 4, 2020.
  1. ninehk
    ninehk Bobtail Member
    20
    Jun 10, 2020
    As the title says I’ve seen some people rev the engine and then release the clutch to take off or reverse is there a reason for that ?
  3. Tb0n3
    Tb0n3 Road Train Member
    4,743
    9,662
    Oct 5, 2012
    Earth
    Some trucks have a weak idle, and others need power coming up a hill from a stop. Usually idle works fine, but no need to stick to what the teacher taught you. Learn how to use your truck better.
    Bean Jr. and Rideandrepair Thank this.
  4. SmallPackage
    5,827
    18,677
    Dec 20, 2019
    Marion Texas
    If you are talking about a quick blipping of the throttle than release the clutch that I think is done by some guys as a signal that the truck is about to move.
    If it’s a rev and hold while the clutch is slipped/released than that is probably just bad driving habits.
    Bean Jr., Rideandrepair and magoo68 Thank this.
  5. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    No.
  6. rbrtwbstr
    rbrtwbstr Road Train Member
    3,403
    7,953
    Jul 11, 2012
    in the bush somewhere
    I drove a Ford L8000 with a mechanical 8.3 liter Cummins for a while. That thing was so gutless you had to give it some throttle when you pulled out from a stop.
    It's just a habit for some people I guess.
    Rideandrepair, D.Tibbitt and Tb0n3 Thank this.
  7. wis bang
    wis bang Road Train Member
    3,476
    4,134
    Jan 12, 2011
    Levittown, PA
    1968 Mack R600 would stall on steeper grades.....another gutless wonder w/ the Maxi-torque 5 speed...sign said hill, time to downshift to 4th....on a real hill you worried about dropping down to second....going up Pocono on I-80 I would be passed by Associiated's road commodes....
    Rideandrepair and D.Tibbitt Thank this.
  8. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,900
    Sep 20, 2015
    Southern Ontario
    I find that driver’s that raise the idle and hold while letting off the clutch pedal is usually due to weak idle power or bad driving habits.
    My M11 330 hp engine will pull a loaded 5 axle trailer at just idle and letting off the clutch pedal.
    Brettj3876, Rideandrepair and magoo68 Thank this.
  9. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Only point to side stepping a clutch is to destroy the drive shaft.
  10. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Short answer with today modern engine....NO! Reason they do this....just look at what is "teaching" these youngsters to operate the rig....no experience, none if any knowledge and loaded with bad habits they are just passing on.
  11. abyliks
    abyliks Road Train Member
    4,160
    9,811
    May 2, 2010
    ludlow MA
    That’s because people are idiots and don’t know how to select low gear to take off and would rather destroy a clutch starting off in second or third, 190, 220, 237, 290 horse I have never had to rev the truck to take off
