RF noise through the coax...any fix?
Discussion in 'CB Radio Forum' started by paul 1052, Jul 26, 2011.
  1. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    After replacing the stereo amp in the overhead in my 379 I'm getting a whirring coming in through the coax, is there a fix for this?
    Or even a way to manage it down?
  3. Yup
    Yup Medium Load Member
    569
    129
    Apr 2, 2011
    Everywhere,USA(Texas)
    Amp isn't grounded well enough,check for a screw somewhere on the chassis
    If there is one,you will have to run a ground from there to solid chassis metal.
    I have a 2500 watt tune kicker and it has the external ground provision,ground everything true to chassis of vehicle.
    paul 1052 Thanks this.
  4. paul 1052
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    I've been wondering about that, the factory amp was bolted to a frame ground and they used 3M sitck'em to hold this one down..thanks. I'll try a better ground tomorrow.
  5. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Sparky sells a double sheild RG-58 it helped me here
  6. paul 1052
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    I'll look into that too...thanks
