Ride height
Discussion in 'International Forum' started by down south, Nov 23, 2018.
  1. down south
    down south Bobtail Member
    37
    6
    Nov 4, 2016
    How do I adjust ride height on 2007 9400I International?
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    If you have "IROS" suspension, the leveling valve is on the front axle usually. The leveling arm is two piece with a small bolt on the middle that when loosened will allow you to pivot the arm slightly to make small adjustments.
  4. down south
    37
    6
    Nov 4, 2016
    Type of work I do it hit pot hole broke rod everything it’s hitting stop the reason I started looking at ride height
