Right side antenna comes in where?
Discussion in 'Freightliner Forum' started by honorjr, Jun 25, 2011.
  1. honorjr
    honorjr Bobtail Member
    Pensacola, FL
    New to a 2007 Columbia. Is the right side antenna for TV like most trucks? If so, where do I find it inside the truck? I am used to finding a terminal inside for TV cable in other trucks.
    Thanks
  3. 25(2)+2
    18,759
    45,986
    Sep 18, 2006
    the road less travelled
    Most of the FLwith 70 inch or larger sleeper have a place for the TV in the cabinet stack on the passenger side about 38 inches above the floor. The truck will have a piece of coax with F connector in there if it is equipped, there is also usually a 12 volt lighter type outlet inside as well.
  4. honorjr
    Pensacola, FL
    Should have stated it is a 58" mid-roof. Does not have the typical tv spot. The previous owner left a flat screen mounted on the wall. I did not get it directly from that owner so can't ask him.
  5. 25(2)+2
    18,759
    45,986
    Sep 18, 2006
    Is it hooked to a cable?
