Right tank keeps filling up! HELP
Discussion in 'Experienced Truckers' Advice' started by mizdageeragn, Jan 16, 2011.
  1. jim9660
    jim9660 Bobtail Member
    Buffalo, NY
    If both return lines are clear, then see if the fuel lines or return lines are different lengths from one tank to the other. If there is a big difference, the shorter hoses will draw faster.
  3. ChromeDome
    ChromeDome Road Train Member
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    You should still have something that goes tank to tank.
    No fuel system I have seen is designed to where the fuel has no way for gravity to equalize it.
    They can clog inside the tank as well. From junk settling on the bottom.
  4. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    My '07 Volvo 780 does NOT have a crossover. The only way the fuel tanks can equalize is from the fuel being returned from the engine by decisions of the proportioning valve. When the engine is off then the valve must open allowing them to balance as well.
  5. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    I've never had it over fill the other tank before but I have had trucks that draws fuel unevenly. Top off, one will get down to 1/4 but the other one will be up at 3/4 full.
  6. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    Had the same thing happen on an 05 Shaker. Proportioning valve went bad. Ran me out of fuel on Tiger pass, on the passenger side tank (hwy 18 WA, no shoulder). Made for a nice traffic jam. Since the fuel gauge read the drivers tank, it said full.
  7. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Freightliner??? Just for grinns...look under the drivers door and above the fuel tank and see if there are two yellow handles there.....yes? Push them in... hard. No?...no idea...
    These are great for pulling pranks on your fellow driver.
  8. mizdageeragn
    mizdageeragn Medium Load Member
    358
    183
    Jan 22, 2009
    almost there
    Planing on working on it this Saturday...if not toooooo cold!!Thanks to everyone for all the helpful suggestions. will try to post if I find the problem asap.
    THANKS AGAIN
    THIS REALLY IS THE BEST TRUCKING WEBSITE EVER!:biggrin_25514::biggrin_25514: :biggrin_25514::biggrin_25514: :biggrin_25514::biggrin_25514:
