Road test in automatic truck?
Discussion in 'Experienced Truckers' Advice' started by Hawkeye72, Feb 25, 2023.
  1. Hawkeye72
    Hawkeye72 Light Load Member
    273
    833
    Feb 20, 2015
    Iowa
    When I originally got my cdl it was in a manual truck and shifting while in intersection or crossing rail road tracks was I belive a automatic failure.
    How does that work in a automatic truck? Do I need to put the truck in manual mode? Or do I just let the truck shift normally? This will be for a company not the DOT if that matters. Thanks in advance.
  3. Concorde
    Concorde Road Train Member
    5,482
    19,490
    Jun 29, 2016
    West Melbourne Florida
    Just mash the throttle to the floor and let the selectomatic transmission do what it wants :)
    No shifting on RR tracks is exclusively for manual gearboxes.
  4. Accidental Trucker
    Accidental Trucker Road Train Member
    3,439
    7,815
    Jun 4, 2015
    Point it east, hit the go pedal and find a good station to listen to.
  5. lual
    lual Road Train Member
    5,340
    9,750
    Oct 22, 2020
    SW Georgia
    That's a really good question.
    This is one of those cases where more modern, up-to-date technology has pretty much taken an earlier problem completely off the table.
    When I took my road test for my fuel hauling gig--i just let the auto transmission do the work--no need to shift the tranny into "manual" mode.
    Another thing to keep in mind for fuel hauling (while doing a road test, or not)--if the tractor is moving, regardless of how slowly....or how short the distance....or backwards or forwards....BE SURE YOU ARE WEARING YOUR SEATBELT.
    Yes....it's silly. Believe me--I get it. :rolleyes:
    But the safety depts in the fuel or cyro hauling worlds think like that.
    You will also have to live with a driver-facing camera, too. Get used to it (if you're not, already).
    I would respectfullly submit--that said camera is not "watching" you ALL of the time.
    It only runs when a "recordable event" sets it off.
    If the tractor is moving, and you are not wearing your seatbelt, this could easily set off the camera.
    You may thus flunk your road test--even if you did fine, otherwise. :rolleyes:
    Hokey? Yes. But it's the modern reality of fuel hauling (or hazmat tanker, for that matter).
    --Lual
  6. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    I think pretty much everything will shift a gear through an intersection. When stopped.
    Unless you have a big motorcycle with tall gears like mine.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Do any companies treat the road test as more than a formality?
    Everyone I've ever done was simply "Don't hit anything and you pass"
  8. Moosetek13
    Moosetek13 Road Train Member
    14,986
    19,038
    Nov 1, 2010
    Burnsville, MN
    It is always on and recording, so it is always watching you.
    If an event is triggered it saves the footage from 10 seconds before to 10 seconds after the trigger to a separate folder, which is later uploaded.
    If it only ran when an event is triggered it would not have that previous 10 seconds of footage.
    None of us is really privy to the actual memory capacity of these cameras. They could hold days worth of footage that can be later uploaded and reviewed.
    I have seen videos of recorded events, and they went back into previous days to gather more clips of the driver doing the same thing that he was doing when an event triggered. In that case it was watching movies on a tablet that was seen through the windshield reflection.
    Watching the movies didn't trigger an event, it was hard braking that led to an accident.
    But they had earlier footage, so there is some generous amount of saved video that was not uploaded but available and accessible.
    Make no mistake...
    It is always on and watching.
  9. Moosetek13
    14,986
    19,038
    Nov 1, 2010
    Burnsville, MN
    In my road test, the real test was the right turn onto the last road leading back to the terminal.
    I did it during rush hour in Fontana, CA.
    Turning onto a narrow 2 lane road with lots of traffic, so both lanes were needed.
    I must have waited there for 10 or more minutes before I could use both lanes and make the turn without curbing the tandems, all the while blocking the cars behind me.
    I was told after the test that that last corner failed more drivers than anything else.
    One part of the test is patience and prudence, it seems.
  10. lual
    5,340
    9,750
    Oct 22, 2020
    SW Georgia
    @Moosetek13 --
    THANKS SO MUCH...for that correction.
    I described the function of the cameras as per the above....so perhaps Hawkeye wouldn't be nervous during his interview road test. :D
    The hope was....he wouldn't learn/find out the not-so-pleasant truth about those cameras until later....:-(
    But thanks again....I have thus been "put in my place"....:violent3:
    -- Lual
  11. mwonch
    mwonch Light Load Member
    293
    286
    Dec 3, 2014
    San Antonio, TX
    For testing purposes? They know you can't control when automatics shift, so it won't count against anyone should it do so at that moment. As someone else pointed out, that rule is only for manual shift.
