Road test in doubles? New driver.
Discussion in 'Experienced Truckers' Advice' started by coastietruckin', Apr 5, 2018.
  1. coastietruckin'
    coastietruckin' Light Load Member
    269
    148
    Dec 28, 2015
    Southern NJ
    Have any of you guys done a road test as a NEW driver in doubles before?
  3. MidWester
    MidWester Light Load Member
    90
    57
    Oct 13, 2015
    I think Fedex Freight road tests the road drivers in sets.
  4. coastietruckin'
    269
    148
    Dec 28, 2015
    Southern NJ
    Same with UPS. I have my test on Monday, and am mentally preparing for it. I've never hooked or driven doubles before, but will have the tester with me and am planning on just taking my time.
    Any tips?
  5. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    Sure!
    To qualify, you gotta prove you can,put a full set in the ditch on a clear, sunny day,on a straight, flat road! Bonus points for any added destruction and mayhem!
  6. coastietruckin'
    269
    148
    Dec 28, 2015
    Southern NJ
    Lol. Oh Christ, this oughta go over REAL well.
    I've been loading up on YouTube vids and am hitting the yard tmrw to practice my pre-trips and airbrake test. I at least want to be spot on with those.
    brsims Thanks this.
  7. MACK E-6
    50,050
    238,545
    Always crack the valves on the back one. This is very important to make sure you have air all the way through the system.
    And make sure your pintle hook is locked. ;)
    Wargames, Lav-25, rearview and 2 others Thank this.
  8. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Safety chains , make sure they are hooked up.
    Wargames, Lav-25, JReding and 2 others Thank this.
  9. coastietruckin'
    269
    148
    Dec 28, 2015
    Southern NJ
    Copy that. Crack that service air valve in the back. Are the turning characteristics majorly different from pulling a 53' with a sleeper? I know that there's the 2 pivot points, so I didn't know if it makes turns a little tighter. Should I take a wideer approach heading into turns with the tractor? Or drive as I normally would with a '53?
  10. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Do your hookup methodically. The same sequential procedure each time. I always hookup safety chains first.
    You look like a boob dragging unsecured safety chain on ground into the yard.
    You look like a boob if you lose your wagon because your chain was not secured
  11. MACK E-6
    50,050
    238,545
    No, both of them. At the very least, it made me feel better.
    A set will turn corners that a 53’ can’t, but if you’re not used to that you won’t think so. Just drive normally, but steer gently. Watch that “crack the whip” effect.
    Wargames, Lav-25, JReding and 3 others Thank this.
