Road test tomorrow, any tips?
Discussion in 'Questions From New Drivers' started by TruckerTranslation, Mar 28, 2019.
  1. TruckerTranslation
    TruckerTranslation Bobtail Member
    Mar 28, 2019
    So i have a road test tomorrow but i havent driven in 2 months! Im scared im going to fail it? Any tips?? Thanks!!! (automatic trucks)
    bark77 Thanks this.
  3. Ironwindow
    Ironwindow Light Load Member
    125
    156
    Mar 1, 2019
    Winston Salem, NC
    Watch the signs and call everything you see. Keep the speed about 5 below just to make sure you don't go over.
    Know where your trailer tires are.
    homeskillet Thanks this.
  4. D.Tibbitt
    157,285
    Dont hit anything
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You are taking some one for a nice drive. Aint nothing you can do that will rattle Mr and Mrs Clipboard.
    Be happy, you aint forgot how to ride a bike and 18 wheelers are easy. Ive been away from them almost 10 years but give me about 10 minutes and I'll be ok. Two months, you should be fine.
    BigDog Trucker and Philglo2354 Thank this.
  6. TruckerTranslation
    Mar 28, 2019
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Drive it like you stole it!
    BigDog Trucker and Ray Strack Thank this.
  8. MM71
    MM71 Heavy Load Member
    760
    992
    Jun 28, 2008
    AZ
  9. WesternPlains
    6,369
    57,409
    Sep 1, 2017
    Rapid City, SD
    Don’t run over the tester.
    sdaniel and 1029384746 Thank this.
  10. DenBob
    DenBob Light Load Member
    283
    442
    Feb 19, 2018
    Don't worry about failing.
    I failed 4 times.
    That's what I tell people anyway
    Actual number is higher.
  11. SteerTire
    SteerTire Road Train Member
    1,414
    2,347
    Nov 5, 2018
    Behind the wheel
    I’m assuming this is a company road test.
    Just drive the truck. Auto or manual, it’s all the same. There’s one slight difference, you may ask the person giving the test what their expectations are with regards to that difference.
    Railroad crossings. An auto will shift while crossing, unless you put it in manual mode. Some want you to do just that. Others don’t care.
    x1Heavy and Dan.S Thank this.
