Kenmorth T600 straight truck, tandem axle, air ride rear, spring fronts.
Air system has two leveling valves for rear system.
When loaded truck rocks side to side when traveling.
Is it possible these valves are ‘fighting against each other’?
While its rocking, it is not like it gradually leans over than gradually comes back, it like it leans, then hits a point than quickly snaps back to level, then gradually leans the other way, then hit a point then snaps back again, rinse repeat.
Rocking suspension
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lazer, Oct 18, 2020.
Generally dual levelling valves are much more stable than the single valve setups.
I have come across this issue before on another truck. Dual leveling valves but one was replaced with the wrong valve. One was more sensitive than the other, so the sensitive side dumped/filled the bags on that side much more rapidly. Swapped it out so they both matched and it was all good.Dino soar and spsauerland Thank this. -
Leveling valves should be for axle not for side. Check if some mechanic messed up it.
A levelling valve for each side is actually a legitimate factory option from most manufacturers. Typically found on trucks that run off pavement often. Very rare to see on a highway spec truck.Dino soar, p608, spsauerland and 1 other person Thank this.
Kenworth used them on trucks early to mid 2000s and i am sure others. They were most common on the 8 bag suspensions. I removed one valve on the ones that i could not get to work right for long and ran the valve on LFD. It may have been intended to stabilize cornering but i have no idea.
Snailexpress Thanks this. -
Yes, this is a 2006. Actually and thankfully 90% of the fleet is pre-def, pre-regen. 100% manual transmissions.
This particular truck has a 4300 gal, single compartment tank on it. So with natural rock, and surges with hauling liquids having leveling valve not working proper adds to the excitement. -
I can only imagine. I have hauled oil in trailers and milk in a straight truck. That's a big tank.Lazer said: ↑Yes, this is a 2006. Actually and thankfully 90% of the fleet is pre-def, pre-regen. 100% manual transmissions.
This particular truck has a 4300 gal, single compartment tank on it. So with natural rock, and surges with hauling liquids having leveling valve not working proper adds to the excitement.Click to expand... -
What is the effect of that?AModelCat said: ↑A levelling valve for each side is actually a legitimate factory option from most manufacturers. Typically found on trucks that run off pavement often. Very rare to see on a highway spec truck.Click to expand...
Does it improve traction? -
Stability mostly I think. Rather than all 4 corners being equal pressures, the bags on each side are equalized.Dino soar said: ↑What is the effect of that?
Does it improve traction?Click to expand...
With a single valve, the truck will lean if its loaded heavy on one side. With dual valves, the heavy side will get more pressure in order to keep the frame level.baha, pushbroom, swaan and 1 other person Thank this.
Related Categories
Ipd endurance kit in 7fb...
Bfarms92 posted Mar 25, 2026 at 9:34 PM -
frame crack. how urgent.
4noReason posted Mar 25, 2026 at 7:18 PM -
14L Detroit loss of power and...
Andres Guerrero posted Mar 25, 2026 at 4:23 PM -
Cat 3116
jagmohannavindra8 posted Mar 24, 2026 at 11:38 PM -
2012 FREIGHTLINER DD15 NO START
PROMOBILE posted Mar 24, 2026 at 11:22 AM -
Rebushing gen 1 vnl torque rods?
Appalachian_Soul posted Mar 23, 2026 at 9:41 PM -
2005 T800 Wiper relay location
Timberwolf9653 posted Mar 18, 2026 -
C15 Acert Transfer Pump
Bentwrench posted Mar 16, 2026 -
System saver 1200
ColumbiaBoB posted Mar 16, 2026 -
1st gen volvo air switch...
Appalachian_Soul posted Mar 15, 2026
Loading...
Recent Threads
Haz-mat study guide for Illinois
istumped posted Mar 25, 2026 at 8:43 PM -
Best route
Rideandrepair posted Mar 25, 2026 at 3:49 PM -
Texas DPS Medical Certification
spindrift posted Mar 25, 2026 at 8:40 AM -
Anyone from Texas ?
TruckRanger posted Mar 25, 2026 at 7:14 AM -
Cat 3116
Education materials
CatAstronautCrew posted Mar 24, 2026 at 11:22 PM -
Dd15 won't complete regen
MTMAUS posted Mar 24, 2026 at 10:58 PM
Loading...
