Roll back
Discussion in 'Questions From New Drivers' started by Mr. EastCoast, Nov 4, 2020.
  1. Mr. EastCoast
    Mr. EastCoast Light Load Member
    80
    65
    Aug 26, 2020
    How do you prevent roll back on a hill?
  3. Dumdriver
    Dumdriver Road Train Member
    1,525
    2,138
    Jul 8, 2014
    East Coast
    when? When the light is red (and you’re stopped) or when you’re taking off? It’s slightly differebt
  4. Badmon
    Badmon Heavy Load Member
    806
    1,503
    Oct 6, 2014
    Deep south
    Hold the brake and ease off the clutch very gently until just as it starts to grab. Then let off the brakes and roll out
    Roberts450 Thanks this.
  5. Moose1958
    Moose1958 Road Train Member
    15,157
    33,336
    Dec 17, 2010
    Williesburg, Virignia
    A short rollback from time to time is not going to do any harm. The largest way to keep rollback to a minimum is to learn the proper gear to be in and respect the available torque the truck's main engine can provide even at idle! Once you learn to get everything in sync your rollback problem should go away. Just let out on the clutch until you feel the drivetrain engaging then at the same time slowly release the brake, then as you gain speed start changing gears.
  6. AModelCat
    158,346
    Let the clutch out until it starts to grab, let your foot off the brake and then ease the clutch the rest of the way out.
    Brettj3876 and Badmon Thank this.
  7. REO6205
    REO6205 Road Train Member
    13,172
    60,495
    Feb 15, 2014
    California.
    The way that always worked best for me was to hold the trailer brake lever down and slowly release the clutch and slowly release the trailer brake handle at the same time. Takes some practice.
