Roll off truck questions
Discussion in 'Waste Removal and Garbage Truck Driver Forum' started by Thetrashnoob, May 31, 2019.
  1. Thetrashnoob
    Thetrashnoob Light Load Member
    299
    57
    May 30, 2019
    I’m doing some research to see bout starting my own roll off dumpster rental business.
    Is it possible to get a truck that’s too big when starting out?
    A lot of the trucks in finding in my budget are Freightliner/ Mack/ Peterbilt with either 2 axles in the back or some with a 3rd drop axle. My main focus is going to be 15-30 yard containers. Think those trucks would be overkill starting out? I am also considering the future so the capacity for the future is another thing to consider.
    If anyone has any advice/ thoughts feel free to share! I am all about learning in this stage!!
  3. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Where are you located ?
    Bean Jr. Thanks this.
  4. Thetrashnoob
    299
    57
    May 30, 2019
  5. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    The guy I work for builds single axle rolloffs, he uses International chassis and a regular hoist(nothing special). They're powered by DT 466 Int diesels and Allison auto. They're good for containers in the10-15k range(material in the can), anything heavier and you can install a lift axle and haul up to 30k. Trucks all have air brakes and require a CDL-B w/ air brake endorsement. He also has numerous other rolloffs and trash trucks, mostly Macks. Located in Jersey, delivers about anywhere this side of the Miss.
  6. Thetrashnoob
    299
    57
    May 30, 2019
    What size containers can it haul? How much weight? I feel like you certainly need 2 axles in the back. Most of the trucks I’ve been looking at are later 90s early 00 Mack or Peterbilt trucks. But I feel they may be overkill but I’m not sure
  7. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Its a regular size hoist. Any size can will fit. A couple I've seen have fold down stops you can use to haul smaller containers. The weight is based on your reg, with a lift axle you can haul 30k easy . Triaxle rolloffs can gross 80k in Jersey, I don't know about Mass. We've got triaxle Macks starting @ 25k$ and up. One Pete. I've used a few, all the hoists are the hydraulic type with 65-75k hoists.
  8. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    What do you want to haul?
  9. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Theres a company round here that uses single axle with a drop for extra weight. They are small enough for tight areas but can handle most normal loads. The only restriction is they can't haul 40's. Not a bad setup all things considered
  10. Thetrashnoob
    299
    57
    May 30, 2019
    What is everyone paying per ton to dump?
  11. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Couldn't tell ya now a days. Been out of it for years.
