Rough riding suspension
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lciambotti1, Sep 23, 2019.
  1. lciambotti1
    lciambotti1 Light Load Member
    118
    23
    Mar 6, 2015
    We have a 2007 International 9400I. Truck suspension slams on almost every bump. Checked ride height, replaced 4 shocks back in July and rechecked yesterday. New cab air bags and shocks back in July. Air bags are all inflated. Driver says it slams so hard it knocked the microwave off the shelf. Any thoughts on where to go?
  3. AModelCat
    164,726
    Cab air suspension height good?
  4. lciambotti1
    118
    23
    Mar 6, 2015
    Yep. Checked that as well, and even followed him over to pick up the trailer.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Slams so hard on what? and where and how fast?
    There are some bridges that are bad and capable of this "Slam" you speak of. Throw a mini strap over the microwave and don't go so fast over that spot that slammed the truck.
  6. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Not sure about your international. But if I was in your position I would start check omg bushings and mounts. It doesn’t take much slack in a cab mount to make the shocks ineffective.
    Art Vandelay Thanks this.
  7. Rideandrepair
    17,562
    56,899
    Aug 8, 2015
    Airbags inflated? That’s always a good thing. Did you set both suspension and cab heights to spec? Got to be at correct heights. Next, as mentioned Cab bushings and rear spring bushings
  8. Lazer
    Lazer Road Train Member
    1,849
    2,983
    Jan 22, 2017
    it could be any number of things.
    tire inflation
    fifth wheel position
    axles properly aligned
  9. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Sounds like mine did when it needed new shocks on the cab or sleeper I guess. It got them the very next day when it bottomed out, that literally hurt.
    shatteredsquare Thanks this.
