Rpms
Discussion in 'Questions From New Drivers' started by Coffey, Aug 10, 2019.
  1. Coffey
    Coffey Heavy Load Member
    715
    1,746
    May 14, 2019
    I just want to know what everyone try to keeps there rpms at going up and down hills/mountain with a full load
    FlaSwampRat Thanks this.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Uphill aim for whatever rpms will run the fan fast enough to cool it. Downhill rated rpms on the Jake
    Lepton1 and Coffey Thank this.
  4. Coffey
    715
    1,746
    May 14, 2019
    Here's another question I sometime take 421 from KY to IN with no Jake's and 40 tons I usually put the rpms above 1800 min to keep my from having to use the breaks all the time it's a short hill but is it bad for the engine to keep it at high rpm for prolong periods
  5. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    it depends on the motor and gearing.
    Lepton1, MACK E-6, Bean Jr. and 6 others Thank this.
  6. Dave_in_AZ
    428,611
    ISX / 10 speed / 3.58's
    Usually 1500, maybe 1600 up.
    If your in the correct gear climbing, you should be able to accelerate. If you have the hammer mashed to the floor, and cannot gain any rpm's, then you need to drop it until you can.
  7. Fold_Moiler
    Fold_Moiler Road Train Member
    1,926
    3,529
    Mar 17, 2017
    And that basically sums up all you need to know.
  8. DmitriyKW
    DmitriyKW Bobtail Member
    47
    65
    Feb 10, 2015
    Sacto, CA
    Between 1350 - 1600 is sweet spot for engine. Going up I say stay around 1400-1600rpm. Going down it depends how good your jakes brake and your Gross Weight so 1500-1700rpm is max I would say going down.
    Coffey Thanks this.
  9. Moosetek13
    Moosetek13 Road Train Member
    14,996
    19,063
    Nov 1, 2010
    Burnsville, MN
    My Cascadia with the DD15/DT12 combo will keep the engine around 2200 RPM on a steep downhill grade with a heavy load.
    If the cruise control can't hold it at a steady speed I cancel the cruise with full engine brake, and add a little service brake as needed. If I keep it at or under 2200 there is no high RPM warning.
    But that engine was designed to operate at that speed under those conditions. 2200 RPM while under power will damage it.
  10. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Used to be a time when 1700 would blow up the engine.
    Specially if you kicked the jakes on.
    Us old timers very seldom see 1800.
    Must be why we're called super truckers.
    Coffey Thanks this.
  11. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    i kept my truck in the high rpms. going down the mt for a little too long the other day. started to smell something weird and new.
    Coffey Thanks this.
