RTV Silicone Removal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MRMTRANS, Feb 6, 2026.
  1. MRMTRANS
    MRMTRANS Medium Load Member
    408
    441
    Apr 28, 2015
    I'm trying to remove my drive axles to tighten up on wheel bearings. There is RTV-instead of a paper gasket- that still is a little rubbery. But Im having a very hard time getting the axle flange to break from the hub face on my first assembly. Can anyone recommend a "dissolver"/"digester" (used in an AI search)? I've looked into some products, but all have mixed reviews.
    D.Tibbitt Thanks this.
  3. AModelCat
    164,890
    Nothing will get in there and disolve the RTV. Tolerances too tight, waste of time/money.
    Do you have those wedge locks in the axle flange, behind the nuts? If so, you need to take a BFH to the center of the flange to get those to pop loose.
  4. MRMTRANS
    408
    441
    Apr 28, 2015
    No. Just flat washers. I've already got the first axle to move to where oil is barely dripping out. But I believe I'm going to still hammer a lot. Lots of time. And I am doing all 4 wheel positions. Maybe some dissolver will help after I get each flange to move just a little, and then it would be worth my money to get some?
  5. Big Road Skateboard
    7,129
    40,437
    May 2, 2021
    BFH means you need a bigger hammer. Like 14lb sledge big, whack it in the middle of the axle hard.
    D.Tibbitt and Oxbow Thank this.
  6. MRMTRANS
    408
    441
    Apr 28, 2015
    It's the opposite direction that I'm trying to get the axle to move. I guess it will "mash" the silicone, and make it easier to move them out. I'll try that.
  7. Big Road Skateboard
    7,129
    40,437
    May 2, 2021
    Whack it in the middle hard, it'll pop out.
  8. Ridgeline
    22,732
    123,569
    we use Permatex RTV Silicone Dissolver
  9. MRMTRANS
    408
    441
    Apr 28, 2015
    Whamming a 12 lb sledge in the center of the flange worked. Easy. I was hammering a fat long punch the other direction with a 3lb sledge. Thanks.
  10. Oxbow
    Oxbow Road Train Member
    13,673
    141,787
    Nov 24, 2015
    If your aim was good you didn't damage any of the stud threads!
    W923 and D.Tibbitt Thank this.
  11. MRMTRANS
    408
    441
    Apr 28, 2015
    Nope. 4-5 swings is all it took. BTW..I tried chlorinated brakes part cleaner to ease the removal of old silicone, and it worked pretty good it seems. I didn't want to run and get Permatex. I might get some for the other 3 wheel positions when I pick up the project next week, and see if it comes off easier. I want something that works close to just "spray and wipe." Lol
