run away truck
Discussion in 'Volvo Forum' started by DWR, Jul 1, 2014.
  1. DWR
    DWR Bobtail Member
    9
    I know someone out there can help. I have a 2001 610 Volvo with cummins n14 535 hp....seems to doing it after it heats up and has been driven for awhile. It will be running like it did when it was new,,,and all of a sudden it will start running away,,,,jake will automatly come on. I have ecm set 70 mph road speed and it will blow by 70 and keep climbing past eighty....speed meter bouncing from 20 to 80ty crazy. The engine will not turn truck off or anything...I just have to stand up on brakes and try to slow truck down,,,,then all of a sudden it will go back to running normal,,,,not for long though....never seem anything like it...please help before I kill someone....not really...truck is out of service til I get it figured out.....Thanks to who ever can help,,,,,
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Does it do it when you have the cruise set only? Or same thing when you are driving with cruise switched off?
  4. tumblin dice
    tumblin dice Light Load Member
    201
    99
    Apr 18, 2014
    Jacksonville, FL
    Sounds like the ECM is unstable. Could be wiring or unstable power supply. Can you read any error codes? Good luck with that!
  5. Aireal
    Aireal Medium Load Member
    602
    326
    Aug 20, 2012
    Garden City, TX
    A Dodge pick-up I had would do the exact same thing, with or without the Cruise control on. If I remember correctly ( it was a while ago) it was something to do with the electronic brain and a sensor.
  6. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    911
    Mar 16, 2013
    Put a new ECM in it. We were having issues where my old N14 would derate and have no pedal or nothing, bypassed some part of the ECM and unhooked the Jakes and no problems now.
  7. Derailed
    Derailed Road Train Member
    2,384
    2,657
    Dec 10, 2008
    Upstate NY
    When I was reading this all I could picture was the scene from the blues brothers in the rv with the glued gas pedal.
  8. DWR
    DWR Bobtail Member
    9
    Yes all kind of codes,,,no low oil pressure protection, no low coolant protection, along with many more,,
  9. 70s_driver
    70s_driver Medium Load Member
    611
    358
    May 4, 2014
    Probably your electronic control module? You might try to disconnect the Cruise Control and see if it still does it? Another thing you might try, disconnect your batteries and leave them disconnected a few minutes then reconnect them. Maybe the ECM will reset?
    Back in the old days, Id say it sounds like your motor is running backwards but surely not with one that new? Im sure they took care of that problem a long time ago.
  10. Duramaxxed
    Duramaxxed Light Load Member
    155
    60
    Jan 2, 2012
    Bourbonnais, IL
    I've had a n14 do this to me once. Someone had changed the ecm with a junkyard ecm. The replacement ecm had Eaton top 2 enabled on it. Hit a certain speed and it tried to rev up to ####. Seemed like it was running away.
  11. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    ; I had same symptoms last week on my D13,, dash gauges out ;first they tried a new cluster but the ECM and wiring was contaminated with oil. I had to rewire the engine plus a new ECM some sensors, over 6000$ plus a week in shop.
