Running a 12v refrigerator with a battery
Discussion in 'Experienced Truckers' Advice' started by FellowTraveller, Sep 17, 2026.
  1. FellowTraveller
    FellowTraveller Bobtail Member
    23
    33
    Jun 6, 2026
    Company doesn't have APUs or even auto-start to keep batteries charged. Truck has a 1500w inverter. I was wondering if anyone has experience using an RV/Marine deep-cycle 12v battery to power a 12v refrigerator in the truck? Not sure if the battery would be able to be charged enough after 10 hours driving or if there are any other obstacles to this idea.
  3. Numb
    Numb Crusty Curmudgeon
    4,517
    11,051
    Jan 30, 2012
    Charlotte, N.Carolina
    idle it
    trucker-chase Thanks this.
  4. Zeus 49
    Zeus 49 Light Load Member
    156
    78
    Sep 3, 2026
    10 hours runtime will reset . However depending on temperature and efficiency and wiring . Be careful excessive heat starts fires . You will need to pay attention to temperature and economy . On your unit . I have had both success and failure . Good luck bud .
    FellowTraveller Thanks this.
  5. DUNE-T
    DUNE-T Road Train Member
    7,115
    17,357
    May 10, 2015
    Detroit, MI
    You can get a life po4 battery with a charger and use your inverter to charge it up
    FellowTraveller and Lonesome Thank this.
  6. Rideandrepair
    17,639
    57,070
    Aug 8, 2015
    Truck has a 1500w inverter. What am I missing?
    Arctic_fox Thanks this.
  7. FellowTraveller
    23
    33
    Jun 6, 2026
    Afraid of the refrigerator running down the truck batteries overnight. Maybe it isn't something to be worried about?
    Rideandrepair Thanks this.
  8. 86scotty
    86scotty Road Train Member
    4,933
    13,699
    Aug 27, 2017
    Appalachia
    A 12v fridge will NOT run down your battery in one night if your batteries are in decent shape. I've left them on lots of times all weekend. Unless it's middle of summer it will be fine for a couple of days.
    Rideandrepair and DUNE-T Thank this.
  9. DUNE-T
    7,115
    17,357
    May 10, 2015
    Detroit, MI
    You can also do regular 110v fridge running through inverter. Batteries will not die overnight
    KDHCryo and Rideandrepair Thank this.
  10. tiddlytanker
    tiddlytanker Light Load Member
    262
    791
    May 4, 2017
    Minot, ND
    I ran the factory 12v fridge, another 120v freezer, my laptop and a few other tiny things with the truck off during my 10 hour break and my truck started every morning for about 18 months of that. Now I use this https://www.amazon.com/dp/B0F42CSQWG?ref=clp_hp_h_pc&th=1.
    If all you are doing is charging your phone and running a single fridge, you can run that off the trucks battery as others have said.
  11. Moosetek13
    Moosetek13 Road Train Member
    15,226
    19,525
    Nov 1, 2010
    Burnsville, MN
    If you are a company driver your questions are moot. You can not modify the equipment.
