I have a 96 t800 with led lights on fenders and headlight bezel. Everything works fine but my question is I want to reverse it meaning have my running lights bright and turn signals dim. How would I do that? I tried switching the wiring around but it would just make the running lights bright and when you use turn signals it would flash off. Do I need to do something with the flasher relay?
Running light question
Discussion in 'Kenworth Forum' started by DasAutomatic, Sep 17, 2015.
Physically you can. BUT should you. Wouldn't that make it harder to see the turn signal with your running lights on.
It shouldn't right because how it is now lights are dim and flash bright so if I wanted to reverse that it would be bright then dim when I use my turn signals so it be the same just backwards right?
That's how it's going to work.
